05-09-2008, 02:36 PM   #11 (permalink)
Motorhead
Re: Spread Bore vs Straight Bore Carbs
Vacuum secondaries are not 'held shut' by manifold vacuum, they are pulled open by primary venturi vacuum. There is a tiny hole in one of the primary venturi, I think the passenger side, that connects to the secondary spring/vacuum diaphragm. Your vacuum secondaries will only open if you have enough airflow through the primary venturi to overcome the spring pressure. Switch to a heavier spring if they're opening up too early.
Holley 2300C, 4160, 4160C carbs
'86 Bronco, 460, E4OD; '85 Ranger, 350hp 289, T5, 13.2@105.2
Oo..//.-----' --- '---. ////
OOo;.'-(o)------(o)-' ///
spread bore help ninasteel Thunderbird Pages 3 11-29-2006 04:10 PM
Difference beteen square bore and spread bore carbs. 82GT All Ford Techboard 2 03-08-2006 09:01 AM
Spread-bore carb questions Motorhead All Ford Techboard 11 03-14-2005 09:41 AM
Square Bore vs. Spread Bore Carb gork1rogues All Ford Techboard 8 01-20-2005 01:28 PM
Is there a need to always bore? andysam All Ford Techboard 4 04-21-2002 05:16 AM
Holley
Holley
