05-11-2008, 08:56 AM   #1 (permalink)
82GT
Nothing but clicking when starting...
Ok..here is where I'm at so far:
Replaced starter last week and everything was fine until Friday night.
Went to start car an get nothing but clicking. I have fully charged battery. Car starts when push started but not when jump started.
Here is what I've done so far:
Cleaned battery posts and installed new terminals
replaced starter relay on fenderwell
made sure battery was good and even switched to another one
Here's the weird part: When I swapped batteries, it started right up so I shut it off again and tried to restart and got nothing but clicking from relay again! I'm thinking(and hoping) that maybe it;s a lose connection somewhere. Today I am going to check all the grounds and their connections. I'm also going to see if the headlights dim when I turn the key. That should tell me if the starter is hung up at all
Is there anything else I may have missed or could be bad?
I'll keep you posted
1982 GT
351w(.060), ported & polished heads with 1.94/1.60 valves, 10.3 comp, stealth intake, 274XE cam, Holley 750 dp, Mallory dist., shorty headers, flowmasters, 4:10 gear, c-4 with 3700 stall converter, subframes, electric fan
05-11-2008, 09:21 AM   #2 (permalink)
Re: Nothing but clicking when starting...
The ground to the block sounds iffy...
Plus check for rust or paint under the lead on the starter it's self....
05-11-2008, 09:54 AM   #3 (permalink)
82GT
I also forgot to mention that this is my 1988 5.0 mustang (5spd) and not the car in my signature below. I was also wondering if it could be the neutral safety switch on the clutch petal or would I get nothing at all if that was bad? Where is this located anyway?
Also...how do I check grounds with a mulitmeter?
1982 GT
05-11-2008, 10:04 AM   #4 (permalink)
Bosscat
If it clicks, is not the neutral safety switch
\'70 Boss 302 Cougar Eliminator
Bosscat is offline   Reply With Quote
05-11-2008, 10:05 AM   #5 (permalink)
Bosscat
You check the grounds by looking at them. Take them apart and clean them up.
05-11-2008, 10:06 AM   #6 (permalink)
Bosscat
Neutral safety switch is built into your T5.
05-11-2008, 11:04 AM   #7 (permalink)
1 Bad 88 GT
OK you installed new terminal ends but what about the wires themselves? They can corroded under the insulation and not conduct electricity efficiently.
07 Victory Vegas Jackpot
93 F150 4.9, AOD(winter beater)
89 5spd Coupe, 351C EFI Spyder, AGS 4 suspension
80 LX 11:1 carb'd 351C w/GForce T5, 17x9 95 R's(daily driver).
05-11-2008, 12:53 PM   #8 (permalink)
If it's a LIGHT sounding click then you should double check the clutch depression button under the dash..
The system will give you a light click sound if the clutch pedal isn't pushing it in properly.
FE
05-11-2008, 01:13 PM   #9 (permalink)
82GT
FE
The clicking is definatly coming from the starter relay. The old relay made repeated clicking sounds(like a dead battry symptom). The new relay just clicks once after the key is turned.
Anyhow, the clicking is coming from the relay.
So, the clutch petal switch could be faulty even thought the the relay clicks when the clutch is pressed in??
Tomorrow I'm going to investigate more deeply. I had plans this afternoon and only poped to hood to look for a quick fix...something obvious.
1982 GT
05-11-2008, 02:10 PM   #10 (permalink)
Blulakr
If the fender relay clicks, the clutch safety switch is good. A new starter isn't necessarily a good one. Try having a friend hold the key in the start position with the clutch in while you tap on the starter with a light hammer or a wrench. If it then starts your starter is definately bad.
Better yet, spend a couple bucks and get yourself a 12v test light. Most electrical problems can be diagnosed with this $3 tool. With the clutch in and the key in the crank position you should have power to both the big and small wires at the starter.
'69 Coupe, 351C
'05 Super Crew 5.4L
'06 Fusion SEL V6 (momma's car)
Blulakr is offline   Reply With Quote
clicking solenoid?? Stangboy69 Mustang Pages (1996-2004) 4 07-25-2008 06:19 PM
9"clicking cgrey All Ford Techboard 2 03-12-2008 07:43 AM
clicking solenoid?? Stangboy69 Mustang Pages (1996-2004) 0 03-09-2008 11:11 PM
Clicking noise when turning right... adgdghr123 All Ford Techboard 3 09-28-2004 12:03 AM
65 ford mustang starting problems...Selenoid makes clicking noise tpajn All Ford Techboard 5 07-09-2004 01:23 AM
Holley
