05-11-2008, 07:30 PM   #1 (permalink)
67mills
Serpentine belt system
Want to convert our v belt to newer setup!!Going to use Gm alt ,no power steering or other stuff!! am I on the right track What factory pulleyswill work the best on my 67 289 in a 64 fairlane Thanks Dave
67mills is offline   Reply With Quote
05-11-2008, 07:49 PM   #2 (permalink)
ckelly
Re: Serpentine belt system
The 67 should have a 3 bolt balancer pulley, so none of the later OEM stuff will bolt up. Maybe if you redrilled it. March will probably have something for big bucks. If you switch up to a 70+ 4 bolt balancer, then you can use 5.0 6 rib serpentine items with a March #2004 water pump pulley. If you search, you may find some OEM items that might work.
05-11-2008, 08:20 PM   #3 (permalink)
Gearhead99
I tried a 93 Tbird serpentine belt system on my 68 Cougar. It looked good, but it wouldn't fit under the hood. It put the a/c compressor and others in positions that wouldn't work on the old Cougar.
Had to get a March system. Works good, looks good but....you pay for it.
"Support our Troops"
2007 F-150 "Harley-Davidson", SuperCrew
2004 Thunderbird
1968 Cougar, 347 stroker, dual AFB's
1986 LTD
Gearhead99 is offline   Reply With Quote
Serpentine Belt Routing 89Trooper All Ford Techboard 5 09-28-2005 11:07 AM
ATT: AUS 351C ever use serpentine belt? 1 Bad 88 GT All Ford Techboard 3 07-21-2003 02:39 PM
serpentine belt conversion trimmer All Ford Techboard 3 06-10-2002 10:37 AM
change to serpentine belt woody All Ford Techboard 6 05-15-2002 01:44 AM
Serpentine Belt Setup 68 stang All Ford Techboard 3 12-22-2001 05:23 PM
