05-14-2008, 02:07 PM   #1 (permalink)
mikhett
Custom throttle linkage problem
I built the CTL on the tech article and i cant get the throttle blades to open at the carb but they open with the gas pedal? My problem is the aceel pump seems to be binding also and it wont start until i give it a shot of starter fluid. Im using a holly 4160 with the stock ford kickdown bracket that was used in 62. This is a 390 and i had no problems with the 4100& stock linkage. It seems like the holley linkage needs leverage . As of right now it goes straight backand working the throttlle doesnt move the throttle at all. It only works when you step on the pedal.Thanks.
mikhett is offline   Reply With Quote
05-15-2008, 01:48 AM   #2 (permalink)
PaulS1950
Re: Custom throttle linkage problem
How does the pedal operate them if you can't do it by hand? Are you pulling the throttle lever back the same way the linkage does?
Paul
problem with Custom Throttle linkage mikhett Galaxie Pages 1 05-14-2008 09:02 PM
throttle linkage rod123 All Ford Techboard 6 01-11-2008 03:03 AM
Throttle Linkage ? Slyther65 Mustang Pages (1979-1995) 1 03-31-2006 06:50 PM
Throttle Linkage Slyther65 All Ford Techboard 0 03-30-2006 09:29 AM
Throttle Linkage bud168 Falcon Pages 3 04-30-2004 11:24 AM
