05-17-2008, 12:13 PM   #1 (permalink)
nos707
Tremec Bellhousing HELP????
Does anyone know if a C5AA-6394-B Tremec Bellhousing will fit my 93 Roller 5.0 block?
I've searched everywhere, but cant find out!
Thanks,
Tom
nos707 is offline   Reply With Quote
05-17-2008, 10:39 PM   #2 (permalink)
Cheater
Re: Tremec Bellhousing HELP????
It'll fit the block but what kind if car and what trasnmission?
That part# bell is for a 60's/70's toploader. If you're putting a toploader in a old mustang with a z-bar linkage, it'll work.
If you're putting a 5 speed in a Fox, it uses a linkage so there's no place to attach a cable, a different block plate, clutch fork, a bigger flywheel and you'll need an adaptor that corrects the bell depth and retainer diameter.
1967 mustang 351W TKO
Cheater is offline   Reply With Quote
05-18-2008, 05:12 AM   #3 (permalink)
nos707
A guy has a tremec 3550 for sale with bellhousing (C5AA-6394-B) which was bought for a 351w and just wanted to know if it would fit my 93 302 roller block?
Thanks,
Tom
05-18-2008, 06:06 AM   #4 (permalink)
68fastang
The bellhousing willl bolt to your block and the trans will bolt to that bellhousing but ......
The length of the input shaft is different between the Tremec and toploader.If the seller has shortened the input on the trans to compensate for the difference it will work.If not,the input and front bearing retainer on the Tremec will have to be shortened approx.5/8 inch or a spacer plate used between the bell and trans.
1968 Mustang 347,5spd 11.05@120.85mph NA
68fastang is offline   Reply With Quote
05-18-2008, 11:39 AM   #5 (permalink)
nos707
Thats great thanks!
Here is a pic, I guess I have to use the spacer then!
05-18-2008, 02:02 PM   #6 (permalink)
68fastang
LOL
Looks like you're good to go!
05-18-2008, 03:04 PM   #7 (permalink)
nos707
Does that mean that it will put the trans back 5/8"?
Will it still bolt up in the stock location with the spacer?
05-18-2008, 03:57 PM   #8 (permalink)
n2omike
To install a Tremec in a Fox body, you need a bellhousing from an early Fox body (79-83) that used the SROD transmission. (single rail overdrive, 3-speed with 4th overdrive) Then, it will be a direct swap.
If you use a toploader bellhousing, the cable clutch won't work, AND you'll need that McLeod spacer plate that costs around $175.
Best bet is to use the SROD or buy a steel blowproof bell made for the Tremec and cable clutch.
Good Luck!
66 mustang
05-18-2008, 05:08 PM   #9 (permalink)
68fastang
Is this going in the car in your sig? If so,what Mike posted above is spot on.
Tremec 5 spd Bluemr24 All Ford Techboard 8 04-06-2007 08:47 AM
McCeoud Bellhousing will it interchange between t5 and tremec 3550 KidPoboy All Ford Techboard 1 01-13-2004 12:17 PM
T5 to a Tremec mlanden All Ford Techboard 6 10-13-2003 10:05 PM
another tremec bellhousing question gtnrb71 All Ford Techboard 4 09-27-2003 04:32 PM
Tremec 3550 bellhousing question ChicoB All Ford Techboard 11 09-12-2002 03:56 PM
