05-21-2008, 12:16 AM   #1 (permalink)
machwone
Oil pick up help!!!
I Just got a new oil pan thats a 7qt aftermarket Pan. The pan measures 8 inches deep. I dont know who makes the pan (e-bay) but the stock pick up will not reach deep enough. Can't I just buy one thats for an 8 inch depth? does it have to be matched with the pan? Its for a 351c
Help Please
machwone is offline   Reply With Quote
05-21-2008, 02:30 AM   #2 (permalink)
KULTULZ
Re: Oil pick up help!!!
It has to be matched to the pan for proper performance. Sump height and position in the sump, whether it is baffled, front or rear pickup.
The guy had no idea who makes the pan?
[FONT=Century Gothic][/FONT]
05-21-2008, 11:43 AM   #3 (permalink)
machwone
Nope no idea. Its a front sump that has a box welded on it to make it deeper. Thats it other then the deepness all the other parts look like stock.
05-21-2008, 11:50 AM   #4 (permalink)
blkfrd
You can have the stock one extended if it comes to that, but it must be checked to be air tight after it has been welded together with an extension in place.
Tracy Blackford: Corona, Ca
05-22-2008, 07:56 AM   #5 (permalink)
electrowoman
I would go with an aftermarket pick up for an 8 inch pan. You may have to tweek it but it has to be better than cutting and welding the stock part.
Check out the aftermarket pans and buy the pick up for the one that is clostest to what you have. It should be an easy adjustment from there.
electrowoman is offline   Reply With Quote
05-22-2008, 08:15 AM   #6 (permalink)
ckelly
If it's this one: eBay Motors: Raw 1970-80 Ford 351C 351M 400 Front Sump Oil Pan (item 230253146359 end time May-22-08 20:39:49 PDT)
then try a Milodon #18355 because the pan looks like a knock off of a #30927. The Milodon part with thread into a regular Melling HV pump.
05-23-2008, 12:01 AM   #7 (permalink)
machwone
Yeah thats the one. The pick up is to an 8 quart and I have a 7, but your right it looks just like it. I think that I will have no choice to just buy anther cheap 5qt pan and sell the one i bought. well live and learn
hey any one want the pan? $50 with the gasket set
Pick up a 20 spot Calspec The Garage 25 06-29-2007 02:42 PM
How much ET will it pick up? Bamm-Bamm All Ford Techboard 12 02-18-2005 11:58 AM
Which would you pick!! NoLongerHere The Garage 14 05-31-2004 08:01 PM
how to pick the right cam? gerzen All Ford Techboard 4 10-15-2003 06:58 AM
help me pick a cam luebben All Ford Techboard 6 01-18-2002 10:04 AM
Hays Clutches
