05-21-2008, 10:03 AM   #1 (permalink)
roger waring
Removing side aluminum trim on a 63 Fairlane
Has anybody removed and replaced the side aluminum trim on this type of car? I noticed it appears that the end piece is held on by a stud with nut and as it goes down the car side it is attached by some other type of holding pieces. Do you remove the end piece and slide the aluminum piece, or ?
Thank You.
roger waring is offline   Reply With Quote
05-21-2008, 10:28 AM   #2 (permalink)
Mr.Ed
Re: Removing side aluminum trim on a 63 Fairlane
If you are speaking of the Fairlane 500, the ends of the trim on rear quarters, doors and fenders are held on with clips that have nuts on the back or in case of the door front, a very small bolt. The rest of the trim is held in place with a clip that is installed from the outside of the fender and has clips that are spread apart from the front into the square hole. To remove the trim on these clips, you gently pry it off which shouldn't be too difficult if they are as rusty as mine were.
Most of the clips are available but many are not but you can substitute with some of the ones that are available. A service manual is an invaluable tool in accomplishing this task.
But if you are talking about the plain Fairlane, I don't know about that since I did a 500.
Later!
Mr. Ed
1971 Torino 500 hardtop, 302, Cruise-O-Matic.
Mr.Ed is offline   Reply With Quote
1963 fairlane f/bumper side rear side window emblems roger waring Wanted 0 05-09-2008 12:40 PM
1966/1967 Fairlane trim some comet trim Lupins Parts for Sale 0 03-18-2008 08:46 PM
Removing chrome trim Big Bad Beater Mustang Pages (1965-1973) 3 11-28-2006 06:06 PM
removing coating and polishing aluminum trim tayloredfabrications Galaxie Pages 5 01-14-2006 01:28 PM
Removing the chrome side panals. 68 stang All Ford Techboard 3 07-04-2002 02:40 AM
Hays Clutches
