05-21-2008, 01:23 PM   #1 (permalink)
frdnut
What oil pan for 408?
Well my oil leak has not gone away with replacing the head gaskets and resealing the pan with a new one piece rubber gasket ...It is much better though without the head gaskets leaking and I can see the oil stream coming down directly from the rear seal area on the front of the scattershield....I bought the milodon oil pan (model 30926) used on ebay and I think it may be the problem..It is also leaking along the edge of the sump area along the welded seam......So I am wondering if I should buy a new pan of the same model or try a different brand altogether..Any experiences or suggestions would be appreciated...
Milodon Ford Street and Strip Oil Pans
05-21-2008, 02:24 PM   #2 (permalink)
steharz
Re: What oil pan for 408?
ill add my 2 cents worth here,i used that same pan and could never get it to seal properly-might be worth trying something different mate
81 aussie ltd-351w,rpm heads,performer rpm airgap intake,10.3 com,angus 1.6 rollers ,1 5/8 long tubes,750 edelbrock,comp xe274h,c4
82 GT mustang 302w-4 speed
55 two door ranchwagon
69 xw falcon wagon
steharz is offline   Reply With Quote
05-21-2008, 02:29 PM   #3 (permalink)
torino420
Ditto! Same pan here, I seem to have the same leak. I will confirm when i do my auto to manual swap.
torino420 is offline   Reply With Quote
05-21-2008, 03:13 PM   #4 (permalink)
lafngas
I have the same Milodon pan with no issues or leaks. Maybe I got lucky?
lafngas is offline   Reply With Quote
05-21-2008, 03:40 PM   #5 (permalink)
strtcar
same here
[SIGPIC][/SIGPIC]
1967 Mustang Coupe
[URL="http://chicago-classic-mustangs.com/"]http://chicago-classic-mustangs.com[/URL]
05-21-2008, 03:45 PM   #6 (permalink)
jeffstar
Same pan, no leaks.
65 Fastback:393W, G-Force T5, 4.11:1 Moser N-pro case / 31 spline axles, 4 wheel Disc (low 11's)
05-21-2008, 03:48 PM   #7 (permalink)
Cain
I have that same pan, and mine isn't leaking......yet. I've had it off at least 5 times that I can remember off the top of my head. I know I've used several different gaskets with it. I went with the Milodon crushproof gaskets this time around.
If you go with a different pan, please let us know how it works.
[url=http://www.angelfire.com/creep/drfish/]Look at my page[/url]
Cain is offline   Reply With Quote
