05-31-2008, 08:02 PM   #1 (permalink)
Warlocke
few bits of info needed
first off, what bolts do i need for intake? length, threads, and what grade?
i pulled the oil pan off yesterday, and on the rods/caps its stamped with a cylinder number, im assuming this means the motor has been rebuilt?
also i was reading the wikipedia on the 351w series engines and found out why the mexican block is special, how do i tell if mine is a mexi block?
Warlocke is offline   Reply With Quote
05-31-2008, 08:20 PM   #2 (permalink)
mavman
Re: few bits of info needed
Never heard of a Mex 351w. I've heard of/seen of Mex 302's but never a 351w...not to say that they weren't made. I'm sure there are some out there, somewhere.
Intake bolts--do yourself a favor and pick up some 5/16-18 by 3" long studs and matching grade 8 hardened washers and flange nuts. It makes installing the intake SUPER easy and it torques down properly the first time. Factory length bolts are, IIRC, 2 1/4" long 5/16-18 flange head bolts.
If the rods are stamped with their cooresponding cylinder number, that doesn't necessarily mean that its' been rebuilt. There were some like that right off the assembly line.
05-31-2008, 08:32 PM   #3 (permalink)
iwantmore
Yes to mavman. If you use aluminum heads I would use studs for sure. If you use a regular bolt I would use a thick washer, a quality bolt, and thead lube.
05-31-2008, 08:34 PM   #4 (permalink)
Warlocke
i ment the wiki of the 351w series engines which the 302 is part of. in the 302 section it was talking about the mexi block
05-31-2008, 09:34 PM   #5 (permalink)
Gearhead99
The rods were numbered from the factory.
"Support our Troops"
2007 F-150 "Harley-Davidson", SuperCrew
2004 Thunderbird
1968 Cougar, 347 stroker, dual AFB's
1986 LTD
Gearhead99 is offline   Reply With Quote
05-31-2008, 10:26 PM   #6 (permalink)
Warlocke
ok thanks, one more thing, what does the bare block weigh? im going to try to finish getting it stripped tomorrow. it will be awhile before i can get it machined but this way i know what im looking at.
are the torque specs in the rebuild sbf book from tom monroe?
thanks again
06-01-2008, 04:25 AM   #7 (permalink)
dennis111
There was a Mexican 351w--they can sometimes be found in boats. Every once in awhile they turn up on ebay, but they are indeed rare. The block casting # starts with a number and the whole thing looks like 77ay-6015-aa and they have the Mexican stamping in the lifter valley.
They are similiar to the 71-74 standard 351w castings and are know to have big main caps and a couple of strange looking knobs near the timing cover. Other than that, no different than your run of the mill 351w block.
Here is a pic of one I snagged a long time ago.
Note the "Mexico" casting in the valley and that the distributor sits 1" lower than a 289/302.
Dennis
11.25@122.19mph
Fan info needed wayne64 All Ford Techboard 0 11-15-2006 06:39 PM
balancer info needed EBbronco All Ford Techboard 5 03-09-2006 07:38 PM
EFI info needed junkyardjeff Late Model EFI Techboard 3 11-14-2005 09:56 PM
T-5 trans info needed junkyardjeff All Ford Techboard 4 10-08-2004 01:57 AM
Info needed asap.... deleted3 Galaxie Pages 3 09-28-2003 10:10 PM
