Originally Posted by 72BlackOnBlack
What does it take to change from stock rockers to a set of roller rockers? I heard you had to have guideplates.... Is that true for every application?
What engine? What heads? What cam? and why?
There are many kinds of rocker arms, some are fully rollerize, others less so.
the first division is stud mounted vs. bolt-on. Bolt on rollers can "usually" be installed directly in place of factory rocker arms; so your only issue is whether they are made for the engine and heads you have. The other question, why(?) - goes to the heart of is this just "window dressing" or do you have a reason for making the change.
Re-phrase your question...I'm sure members will be happy to help you make the right decision.
