06-09-2008, 01:38 PM   #1 (permalink)
HitmanKB
Holley Street Avenger Vs Truck Avenger on a Mustang?
I currently have a stock 302 in my 68 mustang with an autolite 2100 2bbl carburetor...
I won an ebay auction for an edelbrock performer rpm intake manifold and a holley truck avenger carburetor 770 for 140... I know the 770 is a large carburetor, but my main question is whats the difference between the street avenger and the truck avenger series? How will the offroad carb respond on the street? I will be doing heads and cam sometime this summer as well.
Thanks,
Kenny
1999 SVT Cobra
1996 3.8L Coupe
1968 302 Coupe
HitmanKB is offline   Reply With Quote
06-09-2008, 03:37 PM   #2 (permalink)
65FalconLover
Re: Holley Street Avenger Vs Holley Truck Avenger...
I believe the truck carb was designed for off-camber stuff like rock crawling and that type of thing. I would guess and say it would work okay but but as you pointed out it's pretty big for a small block like yours.
'65 Falcon Futura (weekend cruiser) Built 289, C4, TCI Street Master 3000 stall narrowed 9-inch and 4 wheel disc brakes. It's not a race car but its raced (a little) and its not a show car but we show it.
65FalconLover is offline   Reply With Quote
06-10-2008, 03:58 PM   #3 (permalink)
HitmanKB
I guess Ill see if I can find some one with a truck and a street carb and see if they wanna swap for a truck carb....
Thanks,
Kenny
1999 SVT Cobra
1996 3.8L Coupe
1968 302 Coupe
06-10-2008, 07:35 PM   #4 (permalink)
iwantmore
The truck carbs have side hung floats just like a lot of other Holleys. There is a vent tube connecting the bowls to keep fuel from spilling over on inclines. It would work fine on a car. It is a little big but with vacuum secondaries it is worth trying and see what you think since you own it. 2 barrel carbs are rated different so the primaries are about like a 500 cfm 2 barrel.
06-11-2008, 05:33 PM   #5 (permalink)
HitmanKB
Should I even try it? 770 Cfm seem huge even if it is a vacuum secondary carb...
The guy that I bought it from had it on a 302 in a ford ranger..
Thanks,
Kenny
1999 SVT Cobra
1996 3.8L Coupe
1968 302 Coupe
06-11-2008, 05:41 PM   #6 (permalink)
htwheelz67
on a stocker that will be pretty big, the good thing is the truck avengers have annular boosters so that will help give better low end and mid and it will idle a bit cleaner, I would try it and install a heavy secondary spring.
htwheelz67 is offline   Reply With Quote
06-13-2008, 09:20 PM   #7 (permalink)
HitmanKB
I guess Ill go ahead and try and well see what happens! I wonder are these carbs any good? They look similar to the barry grant road demon jr line of carburetors!
Thanks,
Kenny
1999 SVT Cobra
1996 3.8L Coupe
1968 302 Coupe
Holley 465 / 470 truck avenger foleysfriend All Ford Techboard 2 06-21-2007 05:59 AM
Holley Street Avenger psivory All Ford Techboard 10 12-22-2005 07:58 AM
Holley truck avenger 470 cfm 1982fordf100 All Ford Techboard 3 10-30-2005 06:06 PM
Holley Street Avenger 65bird All Ford Techboard 4 03-18-2004 02:30 PM
holley 700/750 double pumper VS holley 870 street avenger carbureators!!!!!!! XolieX All Ford Techboard 0 11-26-2002 03:16 PM
Lakewood
