06-14-2008, 10:25 AM   #1 (permalink)
john_bud
351C valve float
Hi,
I'm running a 351C 2v with edelbrock cam, lifters, manifold and 1806 carb (650 cfm), iron manifolds but dual exhaust . Factory valves, springs and keepers. Engine was rebuilt to 2v specs about 13 -14 years ago.
It's been sitting for a few years, but now that it's running, it seems to be floating the valves at about 4800 rpms. Rev'ing up at that rpm it starts to make a lot of smoke, no more power and sounds bad enough to get the foot up quick.
Have the valves taken a set? weakened over time? maybe it's not float but ...what?
I've read the factory valves should be dumped before they drop and new springs installed, but that's a lot of work in prime cruizing time! Any quicker fixes? Or is it time to bite the bullet (or just continue to keep a 4000 rpm red line)?
Thanks,
jb
'73 std convert. 351C-2v with edelbrock 4v on performer intake &cam, Autometer A/F gauge for fun. AOD and 3.25:1 limited slip.
'68 std coup big block Resto in "pause mode"
john_bud is offline   Reply With Quote
06-14-2008, 10:45 AM   #2 (permalink)
PaceFever79
Re: 351C valve float
Is the smoke gray or blue? Sounds to me like you may have an ignition problem causing a high rpm misfire and unburned fuel.
PaceFever79 is offline   Reply With Quote
06-14-2008, 03:06 PM   #3 (permalink)
allenman85
Sounds like weak springs but are you SURE that's it's not FUEL or ELECTRICAL?
1970 Cougar, 3660 lbs
418W, C6, 3.50 posi, slicks & street trim
Best 1/4 mi: 11.24 @ 119 MPH Best 1/8 mi: 7.13 @ 96.32MPH
06-14-2008, 08:29 PM   #4 (permalink)
john_bud
Grey / brown / black --- smoke hmmm can't honestly say as I didn't let it continue for long and didn't look! It was my assumption that it was springs, but...
How would I be able to tell? Springs, fuel or electrical?
Fuel pump puts out 8.5 psi at idle and it has a pertronix (first version) under the cap.
jb
06-14-2008, 08:52 PM   #5 (permalink)
MontegoMan351
Well, you really should replace the valves, springs, etc, because the factory valves are friction welded 2 piece valves, and are known to separate, it's not a really common occourance, but it can happen, and it's not pretty. When I built my Cleveland for street duty, I used Ferrea 5000 one piece stainless valves so I wouldn't risk it.
Just my $.02
'73 Montego MX 357C Homebuilt EFI, 9.5:1 comp, mild cam, 30lb injectors, A9L computer, Moates.net chip, 70mm TB, 76mm C&L mass air.
MontegoMan351 is offline   Reply With Quote
06-15-2008, 08:57 AM   #6 (permalink)
allenman85
The smoke sounds more like a fuel rich problem. The 8.5 psi is quite high (for most applications).
Sounds like we need to find a buddy in your area that understands cars. Where are you located?
06-15-2008, 12:30 PM   #7 (permalink)
n2omike
Could be the lifters pumping up. 351C's are BAD about that. The lifters pump up, then the valves hit the pistons and bend pushrods and/or break the heads off the valves.
For 351C's, I like SOLID cams, 1-piece stainless valves, single groove retainers, and an adjustable valvetrain.
WAY too many 351C's have died from their crappy valves contacting the pistons.
Good Luck!
66 mustang
06-15-2008, 09:17 PM   #8 (permalink)
john_bud
I'm in Western Wisconsin.
I used to understand cars, but as time goes by... Most of my a background is with windsor engines. I've heard of the issues with the Clevelands and just assumed it was float due to weak springs and have limited myself to a 4k redline. It would be nice to be able to zip up to 5500 on occasion, even with the cost of a tank of arab juice.
I've found and fixed a couple issues with the distributor, put a regulator on the fuel line, re-routed fuel line to keep the line cool, tweaked the edel carb for better economy. Haven't run it up again as I don't want to have any damage.
Some other threads list the MSD blaster coil (which I have) as being a possible issue too. Thoughts?
jb
Valve Float or not? Yaap All Ford Techboard 12 06-01-2007 04:20 PM
Valve float? gresse All Ford Techboard 22 03-16-2007 09:11 AM
351C Valve Float? aaronk All Ford Techboard 4 07-01-2004 03:12 PM
valve float? jimmy All Ford Techboard 1 01-27-2004 09:03 PM
valve float? crazyhorse71 All Ford Techboard 2 09-09-2003 03:03 PM
