06-24-2008, 08:39 PM   #1 (permalink)
Matt
Front motor plate
With using a front motor plate for mounting an engine, does a person also need to use a mid plate? Or will a normal transmission mount be fine?
Matt is offline   Reply With Quote
06-24-2008, 09:31 PM   #2 (permalink)
mavman
Re: Front motor plate
Well...lots of people have gotten away with a front plate and rear trans mount alone, but it's a lot easier in the long run to put a mid plate in there along with the limiters. Makes pulling the transmission a breeze if you ever have to. Not to mention that using a front with a mid and rear trans mount (all 3 combined) really stiffens up the front chassis. That's important on a unibody car that has a cheezy sheet metal frame (like mine). If you run a 1/8" steel plate, you can eliminate the block shim plate and won't have to shim the converter or starter...usually. I didn't anyway and I run a 'glide. It works just fine.
When should I consider a motor plate gchero351 All Ford Techboard 3 09-08-2006 02:12 PM
C4 bellhousing front cover plate? polkat C4 Transmissions 1 07-14-2005 01:34 PM
Motor Plate? growlin351w All Ford Techboard 4 07-05-2004 12:05 AM
I need a motor plate bigpres20012001 All Ford Techboard 1 05-11-2004 04:49 PM
351w front motor plate mavman All Ford Techboard 2 01-16-2004 11:10 AM
