06-27-2008, 11:23 AM   #11 (permalink)
retyler
Re: What SBF used aluminum versus cast iron water pump?
The timing cover for a 88 5.0 is reverse flow. You will need to change it.
06-27-2008, 06:49 PM   #12 (permalink)
mavman
Did Ford change the flow of the coolant on the 5.0's? I knew they changed the rotation direction of some of the serpentine belt water pumps but I wasn't aware that the flow was reversed? Is like the LT-1?
Some of the mid 80's big mercurys and crown vics had standard rotation pumps but with a multi-rib belt....and those were mostly aluminum housings. But the inlet was on the wrong side for the application that the OP needs.
06-27-2008, 08:21 PM   #13 (permalink)
iwantmore
Originally Posted by Frank View Post
I know there are several different timing covers out there. This is an 88 5.0 HO I am building for a 28 Ford roadster pickup, but I am using a 65 Mustang radiator. I don't want to run a serpentine system. I had no idea the water pumps had different bolt patterns. I thought it was just the direction of flow, snout height, and outlet side that differed.
So I need a v-belt water pump, outlet to the right (pass side) that will bolt up to an 88 timing cover. At this point I don't care if its steel or aluminum. I am running an electric FP so I'm not concerned about the lack of a mount for a mech pump.
Ideas?
To get it on the passenger side requires a pump about 68 and earlier. I have used forward and reverse pumps on the same cover with no problem as far as the water pump is concerned. The problem you will have is the timing pointer on those early engines is on the drivers side and often cast into the cover. The balancers were also smaller, the wrong balance, and 3 bolt on the early ones. You could use the 70's v belt pump and run your lower hose back to the other side. Those metal hoses with the rubber ends may be the simple way out of this.
06-28-2008, 06:15 AM   #14 (permalink)
2ton
I would recommend an early timing cover/ water pump combo for your application. Like My Two claimed, the early cover is designed to work only w/ the early H2O pump. Find a '62 - '64 Galaxie or Fairlane and grab the cover and pulleys. If you are running an electric fuel pump, no worries about the fuel pump eccentric, just delete it. The H2O pumps are still available new for not a lotta cash. Right side outlet should work w/ the '65 radiator you already have. Also, this timing cover/ H2O pump combo is anywhere from 1/4" to ~ 5/8" shorter than other combos, giving more space between engine and cooling fan. Use the pulleys if you can, the crank pulley is small diameter and is basically a factory reduction pulley. You will need a crank dampener that will accomodate the 3 bolt pulley. Given that you are running a later model HO, you will probably need a 50 oz. imbalance dampener w/ dual pulley bolt pattern. These are readily available from both Jegs and Summit. Since these early cars used generators instead of alternators, while your yarding, grab the alternator brackets off of a '67 -'70 Ford. These brackets work w/ minor alteration on the early pump and locate the alternator low on the right side of the engine. I use this combo pretty regularly. It makes for a simple, clean install that works well. Have fun...
Gotta Hot Rod Ford...
www.roadkillracing.com
2ton is offline   Reply With Quote
06-28-2008, 08:20 AM   #15 (permalink)
rkingston
Edelbrock EDL-8841. $169.99. Aluminum replacement for for the early cast iron SBF water pump. You will spend more time, effort, money, and trouble finding and installing old timing covers, pulleys, and balancers for a stocker than $169. Plus, you'll end up with a new quality pump that will last longer than any rebuild you're going to find at the local parts shop. I'm just saying, spend your money wisely. If you want to PM me, I have a new rebuilt aluminum pump for a 65 289 that I'll give you for the price of shipping. It's sitting on the shelf of my garage because I opted for the Edelbrock.
RK
65 Mustang 289 - Forged Pistons RPM Air Gap 650DP AOD Tranny 9 inch trac-lock w/ 3.50 gears Solid Lift Cam Hooker Headers MSD Ignition Sub Frame Connectors
rkingston is offline   Reply With Quote
1965 289 water pump question (aluminum pump) wildosvt01 All Ford Techboard 4 04-14-2007 03:18 PM
Aluminum vs Cast Iron ShotRod64 Galaxie Pages 2 03-25-2007 07:38 PM
Aluminum Water Pump papacito All Ford Techboard 4 08-06-2005 09:39 PM
Cast Iron vs Aluminum heads futuraman All Ford Techboard 6 02-07-2003 03:04 PM
Water Pump Aluminum or Cast Iron jerrys63 All Ford Techboard 2 07-23-2002 08:56 PM
Holley
