Re: 9" Assembly-what to seal?
Originally Posted by BBPanel
Thank you for the info. I'm a little fuzzy on terminology here. The lubricated seal - is that inside the pinion housing that seals the outside surface of the yoke? I have not removed the pinion from its housing and did not plan to.
The mating surface between the pinion housing and center section where the steel shim is - does it need sealer? -Bob
Yes, the seal that seals around the yoke is in the pinion housing.
The steel shim part of the pinion housing to center section is is sealed by an O ring. No sealant is needed.
Dennis
11.26@122.83mph
