07-05-2008, 08:35 PM   #1 (permalink)
johnsch37
429 CJ or not?????
Hi I need some help.
I have a 429 CJ or what I think is one that I am looking at selling. It was rebuilt about 14000 miles ago and runs like a top. Some people are questioning if it a true CJ besides what the air cleaner has to say. Here are the casting numbers.
Block DOVE A
Heads DOVE C
Intake DOVE 9425 B
Pistons are Flat tops with double eye brows is what one guy said.
Can any one help????
John
johnsch37 is offline   Reply With Quote
07-05-2008, 08:36 PM   #2 (permalink)
ramair351
Re: 429 CJ or not?????
that sound like a thunderjet, N code engine. not a CJ
ramair351 is offline   Reply With Quote
07-05-2008, 08:40 PM   #3 (permalink)
MY TWO STANGS
i would say you have a 1970 4 barrol thunder jet engine this is as good as any but it is not a cj engine .
07-05-2008, 09:08 PM   #4 (permalink)
TorinoStyle2
Yep, regular 4 barrel 429 ThunderJet. If it was a CJ, it would have "D00E-R" casting numbers on the heads. The D0VE block can be the same as a 429 CJ or a 429 ThunderJet, both will have 2 bolt mains, but if it was a 429 SCJ block, it will have 4 bolt mains.
D0VE 9425 B is a standard 429 TJ intake as well.
The 429 TJ motor is still a very good unit, it was quite powerful and rated at 360 horses. You have the early model high compression engine.
For more info, check out 460ford.com :: Index
TorinoStyle2 is offline   Reply With Quote
07-06-2008, 08:23 AM   #5 (permalink)
johnsch37
Thanks for the responces at least I know what I have now.
John
