Re: SideOiler Leaking
Paul,
Your experience with tape vs. pipe dope is very helpful. Of late I use ARP thread sealant for all pipe-type connections-it is really a "pipe dope" anyway. The tef tape was used a long time ago.
That's also what I was looking to learn-the dynamics of a main leak in operation. So you're saying it will spray radially, coat the forward side of the f'wheel and rear of the block and drip only on cool-down? That would explain why I did not see oil pumping out in my 2000 RPM test look. However, it doesn't explain why it was clean and dry when I had the pan off and inspected it. The main cap showed no oil path or mess at all.
Again, every junction, fitting and crevice on the motor is dry and well sealed. I hate leaks as you can tell. I agree, I don't put crap chemicals in the motor.
KULT,
I am not disputing that crankcase pressure can hurt a rear main, only saying that I see no evidence of that. For the record, the oil fill tube also has a breather, so now it wears four, and I admit they are passive not PCV'd. I always wanted to try a drag-style crankcase vacuum pump on which I've seen data which says it helps 15-30 HP as well as ring seal. But there's absolutely no room in a dual-purpose Cobra for that.
Hot pressure near 7000 is approx 85 psi but I'm sweating bullets trying to keep straight and not time to view gauge data.
You guys are great with info and I thank all for the interest in this problem. As said above, I will post the old pics of the plug area when Wifey scans the photos, (soon) just as a point of info.
Looking more and more like I've gotta tear down and get in there, I will drive the car while good weather remains here in the East. I've lived with this for a long time and I'm fed up so when winter maintenance comes I will correct. But I needed the insight you all gave to educate me. Can't thank all enough.
Will continue to post and will definitely reveal the mystery.
Thanks all and welcome your advice.
Hey, a quick afterthought: is there any sense to drop the pan and just change the rear seal, good or bad, rather than rip out half the car to investigate?? Pros/Cons? At worst I think it can make no difference, except for the effort involved.
Any one care to detail the procedure with cautions and pitfalls? (there are always pitfalls when I work). I've never done it in the car rather than an engine stand.
Chas
