07-12-2008, 03:54 AM   #1 (permalink)
86notch
defrent heigth at top dead cnter
I took the head off the right side of my 306 yesturday and seen something a little strang to me,the piston heigth on the second cylider seems to be alot further in the cylinder than the others at top dead center, makes me think the piston pin location is defrent in that cylinder.I was just making sure that I am not crazy and that they all should be pretty close to the same.Any input would be appr.Thanks Chad.
86notch is offline   Reply With Quote
07-12-2008, 05:27 AM   #2 (permalink)
mavman
Re: defrent heigth at top dead cnter
Usually when I see one piston down further than the rest, I think of a bent rod.
07-12-2008, 05:39 AM   #3 (permalink)
86notch
thanks mavman I was sure that something was not right I did not put it together,but I gess I will be takn it apart.
07-12-2008, 10:51 AM   #4 (permalink)
jetnoise
Whats alot?
How did you determine the second slugs tdc?
Was the block square decked?
70 Mach 1 393W
75 Bricklin 357W
07-12-2008, 02:32 PM   #5 (permalink)
Check the DEPTH at the bottom of the stroke and see if they stroke the same.
Bent rod is a possibility, but so is diffrent pin offset, in a piston made my another manufacturer...
07-13-2008, 06:44 AM   #6 (permalink)
86notch
I am going to take a look tonight and see if I can determing what is going on.the piston is in the cylinder about 115 thousands further than the others when messured at top dead center for each.I have not taking the head of the other side yet to check to see if any on that side are defrent,will do that also.
07-14-2008, 04:36 AM   #7 (permalink)
86notch
Took it apart last night and wouldn't you know it ,had a bent rod this came from a brand new 30lb injector that was stuck open from the factory.I have put around a thousand miles on it since that happened with no signs of anything wrong,just took heads of to port match them and noticed the problem.Glad I did as this is going to see boost in a couple of months.Thanks Chad
07-14-2008, 08:02 AM   #8 (permalink)
Wow, glad you found it and I'm glad the car ran after hydrolocking like that!
Good luck on the bottle
07-14-2008, 02:22 PM   #9 (permalink)
mavman
stuck injector? Jeez that doesn't happen very often. I guess that they're just stock I-beam rods? They bend easily...but in a way that is good! If it was an H beam rod or an aluminum rod, it would have most likely broken something (head, crank, rod, etc).
07-15-2008, 05:18 PM   #10 (permalink)
86notch
Yeh it was brand new injector.The rod is stock I have h-beams,but will use them when I build a aftermarket block.I am using the stock block 306 to set my turbo up before I build the other engine.
We Be Dead Murff The Garage 4 05-14-2007 08:19 PM
My nearly dead 302 19mach69 FM Video 0 04-10-2007 07:43 PM
T5 is dead 1993mustang50 All Ford Techboard 1 05-08-2005 08:54 PM
she\'s dead torinoracer All Ford Techboard 22 01-11-2005 04:28 PM
351w manifold heigth and port sizes info for u fogged408w All Ford Techboard 1 11-25-2004 04:23 PM
Lakewood
