Help With Coolant Issue
Having a slight issue with my 68 347. Original 289 block with AFR heads.
When racing it, it pushes coolant into the catch can on the first pass, even in the morning when its cool.
It seems to push a set amount and then seems to stabilize and stay at that amount. When I let the car cool down,
it will pull the coolant back into the radiator. However, there is a net loss of coolant, but not via the catch can, it never gets more than 3/4 full. After a day of racing, the level is down below the radiator core tubes.
When driving on the street it doesn't do this. It occasionally will do it when I drive a little more, shall we say, "spirited."
One other symptom. After racing, the next day, there is a half-dollar size spot of coolant on the floor under the car.
It seems to line up with the oil filter; a little too far back to be the water pump or a hose. This doesn't happen when driving on the street.
I do not smell coolant ever and no apparent steam. There is no coolant in the oil.
The car runs strong. Consistent mid twelves. Sounds very healthy. Spark plugs look good as well.
I suspect that under high rpm (shifting at 6K at the track) the head gaskets may leak and possibly suck coolant or force
pressure into the cooling system. However, I do not smell exhaust or fuel in the coolant.
I was thinking of re-torquing my heads. Is this done by first loosening the head bolts or should I just set my torque wrench to the final value and go over each bolt in the proper order?
Any other thoughts?
Thanks in advance.
[SIGPIC][/SIGPIC]
68 Coupe
347 Scat crank, scat H-beam rods, SRP pistons,
AFR Heads, T5Z, 3.40 Traction Lock
