07-15-2008, 09:23 AM   #1 (permalink)
347LX
cam size = x amount of vaccum
Is there a rule of how much vaccum a motor will have with a given size/duration cam? How much cam can you have and still pull 15" of vaccum?
64GALAXIE 347 STROKER [EMAIL="12.65@107mph"]12.65@107mph[/EMAIL][SIGPIC][/SIGPIC]
347LX is offline   Reply With Quote
07-15-2008, 11:13 AM   #2 (permalink)
BaronVonOttoma
Re: cam size = x amount of vaccum
Well, I know a 292h cam pulls about 9lbs of vacuum in my Mustang.
I'd guess ~270*.
BaronVonOttoma is offline   Reply With Quote
07-15-2008, 12:47 PM   #3 (permalink)
Spali32
I believe mine pulls about 10-11 at 1100rpms. (XE284H..240/246 @ .050)
I used to have the 270H(224/224 @.050) at it had around 17-18 I believe.
[URL="http://www.spalisautodetailing.com"][SIGPIC][/SIGPIC]www.spalisautodetailing.com[/URL]
347 Stroker/XE284H(284/296 dur, 240/246 dur @ .050), BG 650 VS Speed Demon, Ported Victor Jr intake, Jack Roush World Jr Heads (ported from 180cc to [B]195cc[/B])(upgraded to 2.02/1.60 valves) 260cfm/190cfm @ .550 lift, 11:1 comp... 450-475HP
07-15-2008, 01:10 PM   #4 (permalink)
347LX
My 286r solid roller pulls around 10-11 also.
07-15-2008, 03:20 PM   #5 (permalink)
289nate
So nobody thinks things like cubic inches might play a role? I wouldn't put any faith in such a calculation unless it took a BUNCH of things into consideration. Bore, stroke, just about every aspect of the valve events, true compression, heads, intake, exhaust, etc, etc, etc...
65 mustang fstbk, mild 289, T5, 4.11s. 12.76 at 105 mph altitude corrected. In progress of warming up the 289.
289nate is offline   Reply With Quote
07-15-2008, 06:05 PM   #6 (permalink)
BaronVonOttoma
Well sure cubes make a difference, I just assumed he was referring to a 347.
07-15-2008, 06:31 PM   #7 (permalink)
retyler
very well stated. Too many variables left on the table.
07-16-2008, 01:50 AM   #8 (permalink)
PaulS1950
The amount of overlap has as much to do with idle vacuum as the duration does. So does compression, valve size and lift.
so no, there isn't any direct correlation between just the duration and the idle vacuum you can expect.
Paul
07-16-2008, 01:53 AM   #9 (permalink)
Compression has absolutely zero to do with vacuum... It's what occurs AFTER compression that creates the vacuum... or am I wrong, and someone can show me how...?
07-16-2008, 02:04 AM   #10 (permalink)
PaulS1950
The more compression you have the more vacuum the cylinder will pull -
If you start out with less volume as you draw the vacuum it will be higher vacuum at the bottom of the stroke. The same mechanism works for pressure and vacuum.
1" of mercury is about the same as -2psi
Paul
flow amount to hig rev 306 hotmaverick302 All Ford Techboard 65 02-27-2006 10:23 PM
safe amount of nos magoo All Ford Techboard 3 11-28-2004 01:46 AM
9 inch fluid amount? Thordane65 All Ford Techboard 2 08-09-2004 02:26 PM
If you have the least amount of patriotism you should read this Nastystang The Garage 5 09-29-2003 10:17 PM
getting the right amount of travel on a driveshaft BBCFORD All Ford Techboard 3 06-16-2002 12:46 PM
