07-16-2008, 08:21 PM   #1 (permalink)
MARTYMIZE
Help New Cam Selection
I Am Currently Running A Comp Cams
Xfi 248 Hr-14 304/314 Duration @ 248-250 .608 Lift 114 Lobe
I Am Thinking About This Custom Grind
Comp Cams @ 50 254-262 Lift 608 ``4 Lobe
What Do You Guys Think I Will Gain ? And Where At ?
The Current Cam (the Xfi) Is 2800-6200 Rpm
The New Cam Will Be 3300-7000 Rpm
Both Cams Are Hyd. Roller
393 Windsor Fuel Injection With 200 Shot Aod Trans 3800 Stahl 373 Gears In A 92 Fox
Will This Be Worth The $ And Effort ?
MARTYMIZE is offline   Reply With Quote
07-16-2008, 08:24 PM   #2 (permalink)
MARTYMIZE
Re: Help New Cam Selection
Sorry The New Cam Is 114 Lobe
And This Decision Was Made With Help From The Comp Cams Tech Line
07-16-2008, 09:20 PM   #3 (permalink)
DanH
with those specs, best make it a soild roller. going hyd/R that size is more losing than gain
DanH is online now   Reply With Quote
Cam selection torkair All Ford Techboard 38 05-01-2008 12:09 AM
400 cam selection BUCKETOBOLTS All Ford Techboard 14 10-04-2007 02:00 PM
Cam selection UDELOSE2 All Ford Techboard 6 04-19-2005 07:14 AM
Cam selection BLK66FSTBK All Ford Techboard 3 12-30-2002 02:53 PM
Cam selection Oliaar All Ford Techboard 3 11-23-2002 02:58 AM
