07-17-2008, 05:44 PM   #1 (permalink)
tang302
Optimal Deck Clearance
I´d like to know what´s the optimal deck clearance (distance between deck and top of piston) for a street performance 302, WITHOUT BURN THE GASKETS.
I had to mill the block deck, after engine overheating. Now, the piston is 0.004" OVER the deck.
I use ARP head bolts ( 80 lbs/ft. torque ) and Victor Reinz, FEL-PRO 1011, and other gaskets. All of these was burned around quench area (near the water passage).
I want to low the top pistons, but staying a 9:1 compression ratio. I have D8OE heads (69 cc) and I think to mill 0.020" to 66cc.
Thank´s
tang302 is offline   Reply With Quote
07-17-2008, 05:56 PM   #2 (permalink)
n2omike
Re: Optimal Deck Clearance
Optimum safe deck clearance for steel rods is around 0.035". If your clearance is a verified 0.004", get a 0.040"-0.042" thick gasket and call it 'good'. Use the ARP moly lube to torque the bolts to the moly lube specs. They will be lower than the 'oil' specs. That's ok, it's slicker than oil. Add 10ft-lbs to the top row of bolts to compensate for the intake trying to leverage that side of the heads off the deck. Plus, don't over-tighten the intake. Keep going around the intake with a torque wrench until the values settle at 18-19 ft-lbs. You'll need to do it several times as the gaskets relax.
If the surface on the block and heads is SMOOTH, use MLS gaskets when using boost or nitrous.
66 mustang
optimal timing? primrisfastr50 All Ford Techboard 2 04-01-2005 03:11 PM
Optimal Rear End Gear Roguen All Ford Techboard 14 07-20-2004 09:55 AM
Piston to deck clearance / detonation question jeffstar All Ford Techboard 6 02-28-2004 07:29 AM
piston to deck clearance james306 All Ford Techboard 4 05-01-2003 08:52 AM
Zero Deck Clearance 70 stang All Ford Techboard 14 02-11-2003 11:45 AM
