07-30-2008, 06:33 AM   #1 (permalink)
MARTYMIZE
Looking For A Proven Combo 351w Base 750 Hp
I Do Not Want To Start A Build Not Knowing Where I Am Going And End Up With Alot Less Than The Target Hp
Probably 408-427 Cu Does Anyone Know Of A Proven Combo ? Where Can The Information Be Obtained ?
HIGH COMPRESSION WILL BE OK, THIS WILL BE 90% STRIP
MARTYMIZE is offline   Reply With Quote
07-30-2008, 06:50 AM   #2 (permalink)
Cain
Re: Looking For A Proven Combo 351w Base 750 Hp
There was a guy that used to post on here with a 438 stroker that made 750hp. I think there are some videos of him running 8's floating around on this site somewhere. I'm pretty sure he sold his ride so that he could spend more time/money with his family. I'm not sure if he still posts here.
http://www.fordmuscle.com/forums/dyn...o-results.html
I'm sure you could shoot him an email and he'd tell you everything he did to make 750hp.
Look at my page
Cain is offline   Reply With Quote
07-30-2008, 07:53 AM   #3 (permalink)
MARTYMIZE
Thanks Cain
Still Looking For More Combos Guys !
07-30-2008, 08:44 AM   #4 (permalink)
BIGJOE
750 horsepower will cost around 20,000 dollars. I know, I sell engines like this. Do you still want to goo foreward ??
JOE SHERMAN RACING ENGINES
BIGJOE is online now   Reply With Quote
07-30-2008, 09:28 AM   #5 (permalink)
MARTYMIZE
Absolutely Go Fast Or Go Home But I Really Wanted To Spend 16k
07-30-2008, 09:38 AM   #6 (permalink)
DanH
750 HP small block, all parts must be aftermarket. BBF 385 seris can make that with a stock block and live on the street also, you start with 429 cubes and goes up very quick to 572 with the right stock block
07-30-2008, 01:44 PM   #7 (permalink)
torino501
X 2 FOR BIG JOE!!it can be done with some oem stuff,(block crank) but it wont last!
torino501 is offline   Reply With Quote
07-30-2008, 02:07 PM   #8 (permalink)
MARTYMIZE
I Plan On Using A Dart Block For Starters I Also Plan On Using Ported Afr225 Heads (but I Have Been Told That They Will Only Make 650 Hp)
Solid Roller Cam
Looks Like It Is Going To Be 427 Cubic Inch
Eagle Forged Crank And Scat H Beam Rods Srp Pistons.
Victor Intake
Obviously I Am Not Concearned About Doing This Cheap I Just Want To Do It Right ! I See To Many Horror Stories On Here That Say .........well Didnt Make What I Thought It Should !!!!!!!!!!!!
07-30-2008, 02:20 PM   #9 (permalink)
BIGJOE
Your getting a bunch of BAD information. I did a 375 cubic inch engine a few years ago for Hot Rod magazine. It made 816 HP with the AFR 225 heads. Keep on asking for help from people who dont know what they are talking about and you will be allright.
07-30-2008, 02:21 PM   #10 (permalink)
n2omike
You'll need higher end heads for your goal, and the 4.125" bore block (an option) will also be handy. The higher end heads are what pushes the total from around 650hp to 750hp... and the cost from your $16k to $20k.
You might get close to 700hp with the 225's, but unless you are Joe Sherman, you will probably end up around 650.
Drag79stang made around 700hp with his AFR heads that were ported by Ed Curtis, and it did tickle high 8's once he hit it with the bottle. As was said, he has since sold the car. It was a tubbed, lightweight, drag-ONLY car.
How fast do you want to spend? THAT is the question.
If you live close to CA, you just might want to have your checkbook handy, and give Mr. Sherman a call.
66 Mustang, Toploader 4-speed
Pump Gas 306, 10.157@133.68
351W combo 1967PONY All Ford Techboard 6 12-25-2008 09:33 AM
need a proven combo torinostealth Stroker Engines 4 07-10-2008 10:19 PM
351W/T5 Combo harleydude All Ford Techboard 7 06-16-2004 06:04 PM
est hp on 351w combo steharz All Ford Techboard 7 11-13-2003 07:02 PM
351W Combo Canuck All Ford Techboard 0 02-23-2003 07:43 PM
