08-27-2008, 06:19 PM   #1 (permalink)
wohho
Going In-Depth With Ford's Twin-Turbocharged V6 EcoBoost Engine
Hi guys, longtime lurker, first time poster. I just read this interesting article about the nuts and bolts of the twin turbo 3.5 liter Ford EcoBoost V6. Some nice engine porn in there too. 340 HP and 340 lb.ft. of torque starting off at 1500 RPM is incredible for a V6. Can't wait to see what this thing does when it goes into the Mustang.
wohho is offline   Reply With Quote
08-27-2008, 07:19 PM   #2 (permalink)
mavman
Re: Going In-Depth With Ford's Twin-Turbocharged V6 EcoBoost Engine
Interesting. We'll see how long it lasts. Most turbocharged gas engines that I can ever remember weren't the longest lasting engines. Torquey-yes. But also problematic. Let's hope Ford does their homework on this!
08-27-2008, 07:27 PM   #3 (permalink)
dbu8554
well diesels tend to last a long time, but from what i understand the main thing is most people dont let the engine get up to temp properly before engaging the turbo and they dont let it cool down enough when shutting the car down least thats ive heard from turbo guys
08-27-2008, 09:53 PM   #4 (permalink)
BlueOvalBandit
I think that has more to do with the turbo than actual engine lifespan. If you work the car hard and shut down coking of the oil in the turbo bearings can occur. Not really a big deal even in diesel trucks today unless you get it really hot, like a long tow up a steep hill, but most times with todays synthetic oils no cool down is needed. It's usually cooled off doing slow city driving/parking. The newer gas engines are starting to look a lot like diesels with spark plugs. It's even got part of the combustion chamber in the piston now.
No just what the crap am I looking at in that picture, it doesn't even tell me at that site.
1337 |<3`/8()4l2l) <()/V\/V\4|\||)() 51|\|<3
41 6()|23 1|\|\/3|\|73|) 7]-[3 1|\|73|2|\|37
BlueOvalBandit is offline   Reply With Quote
08-28-2008, 01:46 AM   #5 (permalink)
RonEarp
Some companies use turbocharging almost exclusively and have no trouble. Saab's engines (now GM), a large percentage of Audi/VW motors, Volvo, and now BMW. The little 1.8/2.0 Audi/VW turbo five valve per cylinder motor is extremely good and is long lived, I've owned a few.
Americans typically have a sort of bad taste in their mouth from Chysler's experiments with it in the mid-80s. Modern EFI coupled with water cooled turbochargers certainly are a large improvement over dated designs.
Should be an interesting motor, but are they really going to put it in the Mustang? They could have put the old 3.8LSC motor in the Mustang but never did, would have threatened the 5L at the time.
Ron Earp
74 #38 SCCA ITS 260Z
72 Ford Torino 351CJ Four Speed
67 Ford Powered Lola T70
04 Ford Lightning
[URL]http://www.gt40s.com[/URL]
RonEarp is offline   Reply With Quote
08-28-2008, 06:13 AM   #6 (permalink)
mavman
We can't compare a diesel to a gas engine. Diesels...you can boost them at 200 psi if you want to and no fear of running them lean, or at least not as much of a problem. Gas engine-the rods HAVE to be strong if you're going to have boost down low (remember the 2.3?), pistons have to be forgiving, head need good chambers design, plug location must be good, head gaskets must be high quality (remember the 3.8??) turbos have to be able to endure 1800-2000 deg temps, etc. Theres a lot more to be concerned with on a gas engine. If a wastegate sticks shut or a hose burns away, the engine won't forgive.
I realize that modern computer controls can be programmed to take all that into consideration, but keep in mind that it just adds complexity. And I think that each one of us knows that computers aren't always perfect.
Like I said, I hope Ford does their "homework" on this!
08-28-2008, 06:21 AM   #7 (permalink)
falconXR6
I can't believe ford are dropping the aussie 4L inline six in favour of this 3.5L under powered junker.
We've had 500nm of torque on tap from 1800rpm for years now
the latest and unfortunatly last version has 565nm and 310kw.
Nizpro built one to the tune of 1300kw
when some one can do that the 3.5L V6, i'll become interested
falconXR6 is offline   Reply With Quote
08-28-2008, 07:41 AM   #8 (permalink)
dfree383
Typical Maintence Nightmare and Expensive to Fix.......
Why can Ford just get a simple Small 2 Valve V8..... Oh wait a minute GM has been doing it for the last Decade... The LS series, Expandable, Simple and actually pretty efficient.....
"2009 New Years Resolution - Break into the 15's with a JA Custom Cam"
08-28-2008, 10:31 AM   #9 (permalink)
mavman
dfree--my thoughts exactly. Pushrod engines can be efficient! And cheap to build and maintain, which reduces overall vehicle cost and/or increases the profit margin. Why can't they build a pushrod 2V V8...hell even a 4V pushrod V8 with Variable valve timing. I have an idea in my head...dual cams in the block, etc. It can work with today's technology!
08-28-2008, 10:44 AM   #10 (permalink)
RonEarp
Chrysler has a variable valve timing V8 coming out that also includes a variable runner manifold:
http://www.auto123.com/en/news/car-news/a-peek-inside-chryslers-new-hemi?artid=96507
GM has been doing it for awhile and have Vortec auto motors scheduled with variable cam timing:
http://prod.gm.gmgssm.com/experience...LY6_Marine.pdf
And Ford? Well, we're stuck with the blasted modular motors in NA that don't even have the high end valve timing and intake tricks import DOHC V8s have.
Ron Earp
04 Ford Lightning
Turbocharged 2006 Mustang GT - 560 HP 89Trooper All Ford Techboard 10 10-08-2009 09:15 PM
Single/Twin Turbo(s) Engine block Sponge All Ford Techboard 5 11-20-2007 11:22 AM
Has anyone turbocharged an f 150 4.6 gas burner??? streatleathul Truck Forum 1 01-09-2007 06:24 PM
Injected turbocharged smallblock build Cain All Ford Techboard 9 07-16-2006 08:15 PM
anyone running a turbocharged carb trukstopcowboy All Ford Techboard 2 03-26-2006 05:47 AM
