09-24-2008, 02:03 PM   #1 (permalink)
pedal2themetal45
Quick Transmission Question
Hi
I always thought you could push start an automatic as long as you were going around 30mph or so ... Is this not true anymore? One person told me that sence about mid 60's you can't push start an automatic?? any fact to this??
Thank You
Tim
pedal2themetal45 is online now   Reply With Quote
09-24-2008, 04:00 PM   #2 (permalink)
allenman85
Re: Quick Transmission Question
My 1970 restarts
My 1988 restarts
Either one though requires a good bit of speed (30 is fine)
1970 Cougar, 3660 lbs
418W, C6, 3.50 posi, slicks & street trim
Best 1/4 mi: 11.24 @ 119 MPH Best 1/8 mi: 7.13 @ 96.32MPH
09-24-2008, 04:08 PM   #3 (permalink)
More like the late 80's early 90's push the hell out of them and the tranny will not turn the Convertor....
09-24-2008, 04:54 PM   #4 (permalink)
mavman
the only one I know of that was designed to be pushstarted was anything that used an early Powerglide (GM) transmission. Many of them had a rear pump. Out put shaft turned the pump, pump supplied a little fluid to the converter and low gear servo and allowed push start capability. Later PG's did not have the rear pump.
Ford? Not sure. I can't see how they would have push start capability (speaking of a C4, C5, C6, AOD, etc). When teh engine is off, there is no hydraulic pressure so the converter is basically "dry"-relatively speaking. You need a converter full of fluid and a clutch engaged to make the engine turn over.
Matter of fact, speaking from experience....a C4 won't push start at all. I lost brakes at the end of a run once in my Mustang and killed the ignition to help slow it down. Once it lost pressure, it was freewheeling....luckily I was able to start it back up and pull it into low before I ended up in a chicken house.
09-24-2008, 08:31 PM   #5 (permalink)
PaulS1950
Exactly.
The C4, C5, C6, AOD, TH400, TH350 will not push-dtart. they have no rear pump to give oil pressure. You can't even tow them for any distance because the driveline is turning the transmission and it will burn up the transmission due to lack of lubrication and cooling.
Paul
09-24-2008, 11:55 PM   #6 (permalink)
Blulakr
Ditto what PaulS said. Trans has to have a rear (governor) pump to build pressure to allow pull-starting.
'69 Coupe, 351C
'05 Super Crew 5.4L
'06 Fusion SEL V6 (momma's car)
Blulakr is offline   Reply With Quote
09-25-2008, 07:16 AM   #7 (permalink)
pedal2themetal45
OK Thanks for enlightening me.
tim
09-25-2008, 03:57 PM   #8 (permalink)
KULTULZ
The old FORD-O-MATIC and CRUISE-O-MATICS had rear pumps that allowed them to be push started and towed. The rear pump was eliminated with the FMX redesign in 1968.
09-26-2008, 02:46 AM   #9 (permalink)
mmerlinn
Originally Posted by pedal2themetal45 View Post
Hi
Thank You
Tim
To push start you need a rear pump. Most automatics before 1968 had rear pumps and could be push started. About 1968 all rear pumps were history.
Ford 2-speeds had rear pumps & most cruisos did - C4 & C6 did not.
Early GM powerglides did but not the 350s & 400s.
Early Chrysler 904s & 727s did.
No transmission after 1967 had rear pumps that I know of.
mmerlinn (http://mmerlinn.com) -- "Careless and sloppy writers are usually also careless and sloppy at thinking. Answering questions for careless and sloppy thinkers is not rewarding." - Eric Raymond
mmerlinn is offline   Reply With Quote
just a quick question pedal2themetal45 C4 Transmissions 5 08-04-2006 10:58 AM
quick C6 question smuttysmith385 All Ford Techboard 6 06-11-2005 08:21 PM
Quick question.... ZRX61 Galaxie Pages 9 03-18-2005 09:37 AM
Quick Question! aaronk All Ford Techboard 2 07-26-2003 04:10 PM
Quick question Joel-S All Ford Techboard 7 06-17-2002 09:55 AM
