Originally Posted by racecarx111
first off what about motor mounts will the ones off the 5.0 work?
Hey Charlie, yes, those will work.
What about fuel delivery? I know the factory EFI pump wont work without running a return, correct?
Right, and it already has as return line. All you need is a low pressure (return-style or bypass) regulator.
Can I disable the EFI pump and just hook up a Holley blue inline pump up on the existing fuel line?
You could, but it would be easier and cheaper to do the FPR. The pump would have to be removed - not just disabled - and that means removing the tank and fitting a bypass line in the pickup. Yech. You know, you could also place the FPR at the fuel tank and have it return right there, eliminating the long return line. Watch for typical low pressure dead-head vapor lock issues with that, though.
Will the stock tranny crossmember work with a C4, and what about the stock driveshaft? Will I have to get a new one made or have that one cut? It has a AOD in it now that I'm going to remove.
Generally, you'll need to modify your existing crossmember to move the mount forward and up, and the driveshaft may need lengthening or a companion flange spacer, but it's all dependent on your existing dimensions. There are some good articles about this in the forums and tech articles sections.
The motor has a older dura spark distributor, how do I go about hooking it up to the TFI wiring?
You don't. TFI works with an EEC. Duraspark works with a Duraspark box and no EEC, especially in teh earlier years. Easy stuff with the box and wiring from the wreckers. Be sure to get the wiring, as different year systems used different wiring schemes and the coil is sometimes special as well. If you want to use the TFI coil, you can use the diagram
here in most cases.
David
