01-15-2009, 06:16 AM   #1 (permalink)
foleysfriend
4 speed conversion and neutral safety switch
I am in the works with a conversion on a 1966 mustang to a toploader conversion. I have most of the installation figured out but on an automatic it has a neutral safety switch, what do you do with this hook up. Do you by pass it or is there a wire hook up that is used.
Greg
01-15-2009, 08:51 AM   #2 (permalink)
DanH
Re: 4 speed conversion and neutral safety switch
just jump it or can hook a switch to the clutch pedal like late models if your safety minded
01-15-2009, 09:33 AM   #3 (permalink)
Yeah, I'd wire up the NS switch to a switch on the clutch pedal.
A low sun pointed Long shadows toward the east; the tired day was preparing to lay aside its burdens. Far away a lion roared.
01-15-2009, 09:40 AM   #4 (permalink)
ujt389
I have my NS switch wired to a hidden switch so the car cannot be started by just anyone.
01-15-2009, 06:49 PM   #5 (permalink)
foleysfriend
So there is no safety switch on the standard cars. Did the factory not hook any bypass wire or they just didn't hook anything to complete the circuit.
Greg
01-15-2009, 08:43 PM   #6 (permalink)
valleyfirearms
The standards had a reverse light switch on the trans. The reverse light switch is a 4 prong plug and plugs into the neutral safety location in the engine compartment. One half of the plug is the reverse lights and the other side is jumped. The jumped side (red wire) is where the C4 wires would have been if the car were to have been an automatic.
[IMG][/IMG]
[IMG][/IMG]
Thanks!
Mike.
01-17-2009, 07:45 AM   #7 (permalink)
foleysfriend
Thank you.
I thought about my back up lights prior to posting this thread and with those pic's this should work out.
Greg
Neutral Safety switch job1bf Truck Forum 0 07-08-2008 12:16 PM
Car wont turn over, ignition switch or neutral safety switch? MauriSSio Galaxie Pages 22 12-30-2007 04:27 PM
Cranking problem 71-73 mustang -Neutral safety switch- (T-5 conversion) sharpshot71 All Ford Techboard 13 02-21-2007 05:46 AM
BBF c6: uses a different neutral safety switch than sbf? XolieX All Ford Techboard 5 11-25-2003 02:10 PM
Neutral Safety Switch Yellow70Falcoon All Ford Techboard 1 04-30-2003 07:08 PM
