10-26-2009, 10:19 AM
#11 (permalink)
blkfrd
Re: Fuel gauge help
Originally Posted by oneputtster
That was pretty interesting, blackford.
When you switch to an autometer fuel gauge it works ok without the VR, so there one built in?
I am not familiar with autometer gauges. I did a '66 GT gauge cluster retrofit on my car with white faces and then made a board that has 3 SS voltage regulators on it, one for each gauge and the regulators are adjustable so I can calibrate the gauges
Tracy Blackford: Anaheim Hills, Ca
'65 FB Mustang 331, 282S cam, ported 351W heads. T5z, 9" 3.50 posi
357 RWHP @ 6500
10-26-2009, 10:40 AM
#12 (permalink)
65FalconLover
Re: Fuel gauge help
I'm using a Jaz fuel cell with the Ford sender (70-10 Ohm) and the guage is stock '65 Ford Falcon dash unit. I'm assuming the "Ford sending unit" they included is the right one, otherwise I'm looking at the wrong stuff I guess.
I'll get out there today and check the connections, ground, etc. to make sure it's not that.
John
'65 Falcon Futura Pro Street w/347 stroker "The Hot Rod"
'04 F350 Lariat CrewCab dually PSD 4x4 "MOMS CREW"
'06 Acura TL "DADZ TL"
10-26-2009, 10:54 AM
#13 (permalink)
Rich27028
Re: Fuel gauge help
did you unhook the wire that goes to the tank [on the tank end ]-leave it hooked to the dash end -- ground the wire leading back to the dash -- the guage should go to full--- unhook and ground that wire and tell us what the guage does
is the constance voltage reg still hooked into tha line--
66 galaxie 352 -PS-PB-
10-26-2009, 02:10 PM
#14 (permalink)
65FalconLover
Re: Fuel gauge help
I checked the ground and re-did it just for kicks. I then grounded the sending unit wire and it did make the guage read full. Putting back on it still reads 1/4 to 1/2.
I have no voltage regulator on the car as I switched over to a one wire alternator.
John
10-26-2009, 03:15 PM
#15 (permalink)
Rich27028
Re: Fuel gauge help
ok --grounded it went to full- the guage is good --the sending unit is bad-- --
the regulator i ment is the constant voltage reg that is in line with the fuel guage -its up under the dash and is about 1 inch long and about 1/2 inch wide-- if the guage went to full the reg is good -- --either the tank isnt grounded or the sending unit is bad- or the wrong om for the guage--
10-26-2009, 03:17 PM
#16 (permalink)
Rich27028
Re: Fuel gauge help
it also could be you bent the float rod installing it --or it needs to be bent down to make the gauge read higher
10-26-2009, 05:33 PM
#17 (permalink)
65FalconLover
Re: Fuel gauge help
It was a brand new tank installation and the sending unit was pre-installed. The other issue is that it's a foam filled tank so I can't even see the sending unit. I believe it's a "tube style" sender so I'm not even sure if it has a float arm to bend. I thought it was a straight up/down movement type of thing.
John
10-26-2009, 05:47 PM
#18 (permalink)
blkfrd
Re: Fuel gauge help
John
The VR that powers the gauges is a little 3/4" by 1" can on the gauge cluster. Unless you have aftermarket gauges, you still have a VR, just one less because you have eliminated the charging circuit VR with the 1 wire alternator (which just has the VR built into it).
357 RWHP @ 6500
10-26-2009, 09:00 PM
#19 (permalink)
65FalconLover
Re: Fuel gauge help
I'm so electrically challanged it's probably best if I just run the car down to an auto shop fo this. I was hoping for a simple fix but it sounds like I'm wasting all of your time since I really don't understand most of what you're telling me. Sorry. I can build a whole car but when it comes to volts, amps & ohms I'm completly lost.
John
10-28-2009, 08:10 PM
#20 (permalink)
NasalGoat
Re: Fuel gauge help
Where can a person pick up a new regulator?
Jeremy Wilson
1969 Ford Torino GT Fastback
351W 4-speed
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| Fuel Gauge |
acountis |
Mustang Pages (1965-1973) |
6 |
07-23-2009 01:00 PM |
| Fuel Gauge Confusion |
dhop |
Galaxie Pages |
5 |
12-12-2008 05:39 AM |
| fuel gauge 67 |
ODU22 |
Galaxie Pages |
7 |
07-30-2006 06:34 PM |
| fuel gauge |
FoMoCo |
Galaxie Pages |
0 |
06-02-2004 05:28 PM |
| '64 Fuel Gauge...... |
Dogface |
Galaxie Pages |
5 |
12-17-2002 11:14 PM |
