10-19-2009, 12:08 PM   #1 (permalink)
65FalconLover
Fuel gauge help
The fuel gauge on my '65 Falcon never seemed to read correctly so I replaced it a couple of years ago with a new sending unit and that didn't help. It never read full, but would go up slightly after filling the tank.
I just recently replaced the entire fuel tank with a 16 gal. Jaz fuel cell with a Ford sending unit (70-10 Ohms) and I'm still not getting a good reading. When fully fueled it reads 1/4 on the gauge (stock dash guage).
I've put a Ohm tester on the connections at the sending unit. One is marked "G" the other "S" assuming G means ground and S sending unit. The digital instrument is jumping all over the place.
Does this sound like a bad ground or maybe the wire from the guage to the sending unit is grounding out?
Thanks, John
'65 Falcon Futura Pro Street w/347 stroker "The Hot Rod"
'04 F350 Lariat CrewCab dually PSD 4x4 "MOMS CREW"
'06 Acura TL "DADZ TL"
65FalconLover is offline   Reply With Quote
10-20-2009, 09:12 AM   #2 (permalink)
bmcd66250
Re: Fuel gauge help
Either a bad ground (most likely) or the gauge cluster voltage regulator is going bad. Run your own ground wire to the sending unit and see if that helps. IIRC, grounding the gauge wire at the tank will make the gauge read full if it's working correctly.
70 Maverick Grabber, 5.0 (Performer RPM 2.02/1.6 heads, RPM intake, Comp XE266HR roller cam, Holley 650 DP, long headers), "Z" T5 w/Steeda TriAx shifter, 9" "N" case Trac Loc w/3.89:1, 31 spline axles.
bmcd66250 is offline   Reply With Quote
10-20-2009, 02:19 PM   #3 (permalink)
Re: Fuel gauge help
If the Temp gauge works correctly then the volt reg on the dash is fine... They both run off it.
The Fuel gauge power is the same source as the temperature gauge.
Honor!
10-20-2009, 05:03 PM   #4 (permalink)
65 BFX
Re: Fuel gauge help
Did you replace the gauge itself yet? Couldnt tell from your post. Thats the last thing possible really. The ground for the gauge is the same for your other instruments, so if anything else works, its not the ground in your dash. Make sure the ground for the sending unit is to BARE metal, not painted. Good luck.
1965 Cyclone B/FX clone, 347 sleeper 4 speed
1964 Falcon Sprint, 302 4 speed, sub .490 lift, 12.75ET, no NoS
real cars have 3 pedals ;-)
65 BFX is offline   Reply With Quote
10-25-2009, 04:09 PM   #5 (permalink)
65FalconLover
Re: Fuel gauge help
I'll check the ground again, it might not be the best. As I mentioned I'm getting readings, just nothing that makes sense. On a full fill it reads under 1/2 tank. I've already run out of gas once so I'm hoping to resolve this ASAP. With a foam filled fuel cell it's kind of hard to tell where you're at once the level drops under the foam and sticking my hand in there is getting old. ;-)
John
10-25-2009, 04:21 PM   #6 (permalink)
Rich27028
Re: Fuel gauge help
was your new sending unit a 5 om unit-- -it has to match the guage--
66 galaxie 352 -PS-PB-
Rich27028 is offline   Reply With Quote
10-25-2009, 04:46 PM   #7 (permalink)
bmcd66250
Re: Fuel gauge help
I had a gounding problem with mine. I soldered a 90* 1/4" Faston (Quick connect) tab on the outside of the sending unit then ran a ground wire that I can plug onto the Faston tab.
10-25-2009, 07:23 PM   #8 (permalink)
oneputtster
Re: Fuel gauge help
I'm with bmcd. I have a 65 and IIRC the dashboard regulator was only regulating the fuel gauge.
One thing it does is reduce volts to something like 5v to the gauge. If you can rig up 5v from flashlight batteries ande use that source instead of the car battery, that might let you test the gauge and sender.
Putts drives a 1965 Galaxie 500 4dr. 352 4V AC PS PDrumB cruis-o-matic.
oneputtster is offline   Reply With Quote
10-25-2009, 07:54 PM   #9 (permalink)
blkfrd
Re: Fuel gauge help
Thanks, John
Do you mean you put the tester on the connections at the gauge?
The voltage regulator works by closing (12v) then opening (0 volts) then closing (12v) and opening (0v). With an ohm meter on the connections the meter will be jumping all over the place. The VR is just a bi-metal switch very much like a turn signal blinker.
Tracy Blackford: Anaheim Hills, Ca
'65 FB Mustang 331, 282S cam, ported 351W heads. T5z, 9" 3.50 posi
357 RWHP @ 6500
10-26-2009, 05:17 AM   #10 (permalink)
oneputtster
Re: Fuel gauge help
That was pretty interesting, blackford.
When you switch to an autometer fuel gauge it works ok without the VR, so there one built in?
Fuel Gauge acountis Mustang Pages (1965-1973) 6 07-23-2009 01:00 PM
Fuel Gauge Confusion dhop Galaxie Pages 5 12-12-2008 05:39 AM
fuel gauge 67 ODU22 Galaxie Pages 7 07-30-2006 06:34 PM
fuel gauge FoMoCo Galaxie Pages 0 06-02-2004 05:28 PM
'64 Fuel Gauge...... Dogface Galaxie Pages 5 12-17-2002 11:14 PM
