10-25-2009, 06:30 PM   #1 (permalink)
stvrrr
Injector question
I am gathering parts for my 5.0L EFI conversion for my 64 Fairlane and I so far was going to use a stock 89 Mustang upper and lower with the stock 19lb injectors and electronics. Today I picked up an 98 Explorer intake complete with throttle body and injectors. These injectors are smaller diameter and have 4 small hole in the end as compared to the older ones that look to have just a "pin" in the end. Can I use these explorer injectors with the Mustang ecm? They physically will fit either intake, but I am wondering if they will be better or worse for performance. They are the same colour as the Mustang 19LB ones. Thanks
Steve 64 Fairlane S/C 289 lentech AOD 8.8 strut front suspension
stvrrr is offline   Reply With Quote
10-25-2009, 07:49 PM   #2 (permalink)
gbic1
Re: Injector question
Check the resistance and post the part number off the Explorer ones.
1964 Galaxie 428
1966 Mustang 302
1967 Cougar 390
1968 F250 Camper Special 390
10-26-2009, 07:46 PM   #3 (permalink)
stvrrr
I didn't check the resistance but here are the part numbers.
F4SE-A1B
0 280 155 700
and there is a 060
and 571
10-28-2009, 09:17 AM   #4 (permalink)
bassman97
Sounds like the Explorer has EV6 injectors. They use a different style connector than the EV1 so the harness can't hook up to them. They do sell adaptors though.
10-28-2009, 06:45 PM   #5 (permalink)
stvrrr
No the harness/connector is the same as the mustang ones. I will try to get some pictures of the two side by side and post them.
10-31-2009, 07:57 PM   #6 (permalink)
stvrrr
Pictures. From what I have read, the smaller diameter ones have a better spray pattern that atomizes the fuel better.
Injector Question bassman97 Late Model EFI Techboard 2 09-28-2009 09:12 AM
injector question badbird Late Model EFI Techboard 2 07-14-2009 09:15 PM
injector question badbird All Ford Techboard 2 07-08-2009 06:29 PM
Fuel injector question... vinnietbird Late Model EFI Techboard 2 06-27-2005 11:55 PM
injector question rcodenewf Late Model EFI Techboard 4 04-07-2005 10:35 PM
