Re: Which heads for my combo?
Wow those pistons are way down in the hole..I doubt you will be able to make up any extra power with timing because it will likely ping with much advance..My 306 had similar looking pistons .030 in the hole and it was very sensitive to timing . I had to run Premium 94 octane gas or it would ping despite being only 9:1 compression and a cam with lots of overlap....I could be wrong but I think that huge amount of quench is going to be a thorn in your side and limit your potential until its corrected..
What year is your block?...I assume it must be a 73-76 with the tall deck hieght?
