Originally Posted by iwantmore
Were either of the first two masters for stock front discs and what happened? When I think about the physics it would seem that a single piston disc should not need more fluid than a drum brake. The area may be larger but the travel is much less. As you wear the disc pads I can see needing more fluid to compensate for the piston moving in vs a drum set up. So if you monitored the fluid in my mind the drum reservoir would work?
The first one was actually a standard drum brake dual cyl for a 67 Mustang with the round bowl/cover. It did work, hard pedal, but it leaked, I screwed up the seats when I removed them looking for the residual valves/duck bills. The second was for a 76 Fairmont with manual discs, it was remanufactured, the pedal was real spongy and almost to the floor, even after numerous bleedings. It would stop the car, but not under a panic situation. Since its the wifes car I decided to put a decent one on that is for 4 wheel manual discs.
