11-03-2009, 01:27 AM   #1 (permalink)
Domino
Wiring electric choke with Delco alternator?
I have read many posts about wiring the choke wire to the stator terminal on the alternator. How would this work with a Delco 12 SI alternator? Is it possible? If it is possible I will run mine this way. If the stator wire does not put out enough voltage I can use it to trigger a relay.
1962 Galaxie 500 2 door sedan(62A) http://www.cardomain.com/ride/3091676
The car is named Albert(Big Al, not Big Gal!) ¨Built not Bought¨
Domino is offline   Reply With Quote
11-03-2009, 08:10 AM   #2 (permalink)
bmcd66250
Re: Wiring electric choke with Delco alternator?
I have a 12SI. Back when I used to run a choke I just connected it to switched 12v. It won't cause a problem as long as your car starts up in a reasonable time. Otherwise you may have to let the element cool down for a minute before trying to restart. I don't even bother with a choke anymore, in fact I removed the choke horn from my 650dp. Starts right up, runs smooth after about a minute even in below freezing temps.
70 Maverick Grabber, 5.0 (Performer RPM 2.02/1.6 heads, RPM intake, Comp XE266HR roller cam, Holley 650 DP, long headers), "Z" T5 w/Steeda TriAx shifter, 9" "N" case Trac Loc w/3.89:1, 31 spline axles.
bmcd66250 is offline   Reply With Quote
11-03-2009, 09:15 AM   #3 (permalink)
Using the alt was only for convenience rather than necessity.
You should just find a key on 12V hot source and be done with it.
Honor!
11-03-2009, 01:40 PM   #4 (permalink)
bmcd66250
Yep, the reaason for the electric choke being connected to the alternator was that the choke wouldn't start coming off until the engine actually started running and causing voltage to appear at the stator terminal. When the choke is connected to switched 12v it starts getting voltage as soon as the key is turned on. If your car doesn't start quick enough you've got other issues (tuneup needed?).
11-03-2009, 10:56 PM   #5 (permalink)
Domino
I figured it wouldn't be that simple. Ignition hot wires are limited under the hood on my 62. I suppose I will figure it out when I run the wire to power the Duraspark box. I suppose I could tee off of that one and use a relay.
11-04-2009, 09:17 AM   #6 (permalink)
If your car does not start soon enough to keep the Choke from opening with the key being in the on or crank position for a few seconds then something it WRONG with your car.
Simple as that. that choke 12V source can reliably come from any keyed source and be effective.
Honor!
11-04-2009, 03:20 PM   #7 (permalink)
Domino
I won't know how well it starts until next year. I am mocking up the wiring right now. I was wanting to integrate the choke circuit into the engine harness as much as possible.
electric choke 64Ragtop All Ford Techboard 13 06-01-2005 12:34 AM
Electric choke 80351W Truck Forum 2 01-29-2005 11:07 AM
New Electric Choke, Old Car 71TorinoMK Torino Pages 1 01-21-2005 04:48 AM
electric choke NoLongerHere2 All Ford Techboard 1 04-30-2004 07:54 PM
Help With Electric Choke AZ65coupe All Ford Techboard 2 08-04-2002 01:28 PM
