Re: RHS Heads?
The vic jrs are a good head but not in the same league as the CNC ported heads in out of the box form...I think Big Joe has said they are down about 50hp compared to a AFR205....
Also once you get into heads with the valve angles changed from stock like the twisted wedges they start to perform better as well...Just make sure you have pistons that will work with them..
Lots of good reading here although it is probably a little biased towards the AFR stuff..Some good comparisons in the bottom 4 headswap part...
Air Flow Research
