11-04-2009, 07:47 PM   #1 (permalink)
trashline
couple engine building questions
it doesnt look like the lifter bores were messed with. When I pulled the stuck lifters out I had ALOT of trouble. I had to beat them out from the bottom. Should I do anything to those bores? Or should I test fit a lifter first as Im going from hydro to solid.
BCP Custom -> the new budget minded custom parts website
11-04-2009, 08:59 PM   #2 (permalink)
PaulS1950
Re: couple engine building questions
Sometimes as lifters wear out the bottoms will flare making it hard to remove.
Definitely check the bores for damage - CLOSELY. If the bores are not scored then they should be fine.
Paul's Street and Strip
Performance AODs & C4s
paulstephens@q.com
6522 51 Ave. S.
Seattle, WA. 98118
206.725.0881
11-05-2009, 03:12 PM   #3 (permalink)
trashline
ok thanks!
Next
should I polish the main and rods bearings to remove the coating on them to aid in start up?
Should I check crankshaft thrust? if it is to tight how do I loosen it?
When installing the pistons should I coat the bores with my royal purple break in oil or use something else?
thanks
11-05-2009, 04:13 PM   #4 (permalink)
Test fit your new lifters before doing anything to the lifter bores. The only think you may need to do is a little scotch-brite and some finger power with carb cleaner to thinner.
DO NOT hone them with a cylinder hone!
Honor!
11-05-2009, 04:22 PM   #5 (permalink)
fordman460
Posts: n/a
Concerning polishing the bearings: Depends on the bearings you have. Federal-Mogul race bearings dropped the cosmetic tin plate several years ago, and the other companies have followed. Tin is a protection layer for storage and a break-in surface. But the tin plate tends to migrate under load, causing high spots and material thickness variation. It can also be forced into the over-plate alloy under pressure, weakening the alloy mix. If you have tin plated and feel need to detail the surface you're better off with some coarse paper. like a brown shopping bag and a bit of WD40.
11-06-2009, 06:46 PM   #6 (permalink)
trashline
I called Clevitte and they told me NOT to touch the bearings. So that answers that! lol
I really need a good book b/c Im gonna have 1000000 questions
11-06-2009, 08:13 PM   #7 (permalink)
retyler
oil the cylinders with the oil you plan to run in your motor. same for the bearings.
11-06-2009, 08:27 PM   #8 (permalink)
trashline
i was going to use 30weight oil on the bores and the royal purple assmb lube I got for the bearing surfaces. bad idea on the royal purple? I got it for free so I might as well use the 30 dollar bottle lol
11-06-2009, 09:31 PM   #9 (permalink)
james302
Trashline, I like to use 2-stroke racing oil the premix stuff in the cylinder bores during assembly, it burns off fast and doesnt leave gunk all over your pistons. Definately check crank thrust! I prefer to use a dial indicator with a magnetic stand but you can use a set of feeler gauges too. Get yourself a book.
james302 is offline   Reply With Quote
11-06-2009, 09:36 PM   #10 (permalink)
trashline
Open to recommendations! B/c I am LOST. This is gonna make all my hair fall out.
Im reading 4 to 8 thou on thrust for the crank, Im a machinist so I have some good tools to use!
Couple of questions WormsTheHermit Ranchero Pages 7 10-30-2009 06:01 PM
A couple 390 questions Domino Galaxie Pages 11 08-02-2009 08:34 PM
New guy with a couple questions FLINT79 Galaxie Pages 5 05-20-2008 12:03 AM
351w engine (couple questions) torqueman0 Late Model EFI Techboard 7 08-31-2005 06:46 PM
A couple of questions ShadetreeMechanic Galaxie Pages 1 02-07-2005 01:37 PM
