11-04-2009, 09:14 PM   #1 (permalink)
77f100
what cam to use?
i'm looking at 2 differnt camshafts. it's for a for big block 460, weiand stealth intake holley 4160 carb. right now factory cast iron manifold but will upgrade to long tube header before too long. also gonna do very little to no hauling. was gonna go with the bigger cam but i'm leanign toward the more agressive idle. what does everyone else feel? and can i use my stock vaule springs for either of these cams?
Lift: .470/.470
Duration: 278/290
Duration @ .050": 218/218
Lobe Separation: 114 LC
Fair idle quality with lope. Good mid-range torque and response in 2400 - 3200 RPM range. Operating power range 2000 - 4800 RPM. Good fuel economy cam with correct equipment. Good choice for light towing. Compression 10.3 to 1 or less. Will work with stock or slightly modified engine, stock automatic or manual transmission. Recommended spring pressure 110 lbs for valve on seat; 280 lbs for valve open. Axle ratio 3.70 to 1 or higher is best. Recommended for mild bracket racing.
Lift: .486/.512
Duration: 282/292
Duration @ .050": 204/214
Lobe Separation: 112 LC
Good to fair idle quality. Good low end torque and response in 1800 - 2600 RPM range. Good low end and mid-range power in 1500 - 4000 RPM operating range. Good fuel economy cam with correct equipment. Good choice for light towing. Compression 9.5 to 1 or less. Will work with stock or slightly modified engine, stock automatic or manual transmission. Recommended spring pressure 105 lbs for valve on seat; 265 lbs for valve open. Stock axle ratio 3.20 to 4.20 to 1 range. Not recommended for racing.
77f100 is offline   Reply With Quote
11-04-2009, 10:41 PM   #2 (permalink)
L n L
Re: what cam to use?
If those are the only 2 choices, then the bigger one for certain.
65 Factory Five Cobra, 302 efi, t-5, 12.5 @106
'03 Excursion 4x4, 6.0
'69 Falcon Station Wagon, 425W, 4R70W, 3.50, 11.51 @ 117.3, 3790# race weight
11-05-2009, 12:53 AM   #3 (permalink)
fordman460
Posts: n/a
The stock cam is 273°/287°@S.A.E. - 193°/206°@.050" - .437"/.480" valve lift - 113° separation, ground on 110° intake center line. - in the engine at 118° intake center line. Got that from another very trusted person on a different forum. Both the cams you have listed are pretty small for a big block. First one looks to be a small block Chevy design. Second is better but still small for the Weiand intake. A better intake for it would be a Edelbrock Performer. Post what you want this engine to do so as to get a better cam recommendation from some one. The low compression and stock heads will limit the selection a lot.
11-05-2009, 01:37 AM   #4 (permalink)
Ranchero65
With any cam change you need to get the springs recomended for the cam.
Take Care
Earl - Ranchero_65 Restomod Slowley in Process !
http://www.ranchero65.com
Ranchero65 is offline   Reply With Quote
11-05-2009, 02:02 AM   #5 (permalink)
Spali32
I've always heard the Comp Cams 268H cam was a good sounding/good performing cam on a small block. Not sure about on a 460.
www.spalisautodetailing.com
347 Stroker/XE284H(284/296 dur, 240/246 dur @ .050), BG 650 VS Speed Demon, Ported Victor Jr intake, Jack Roush World Jr Heads (ported from 180cc to 195cc)(upgraded to 2.02/1.60 valves) 260cfm/190cfm @ .550 lift, 11:1 comp..400hp(280-290rwhp)
11-05-2009, 10:59 AM   #6 (permalink)
fordman460
Posts: n/a
Ain;t gonna be able to tell that 268h is in there on a 460. Can only here a lope when cold in my 390.
