11-05-2009, 02:59 PM   #1 (permalink)
Toploader Pony
351C distributor
Hello everyone, I'm a newbie here. I'm hoping to find some of you 351C guru's who can answer a few questions about stock distributors for a 351C. i have rebuilt a few SBF and one 351C but i have never had a situation regarding the distributor
- Is there any real differance (other than the gear) between a 351C distributor and a small block ford distributor (289/302) ?
-Will a distributor from a SBF 289/302 motor work properly in a 351C (with correct gear)?
- If it will, what type of gear do i need. i have heard you need a a different gear if you dont have a stock cam in the motor.
-If I obtain a stock 351C distributor that is missing the gear, what type of gear do I need to use on the distributor.
Again, go easy on me here. Its something i am not familair with when it comes to the 351C
Toploader Pony is offline   Reply With Quote
11-05-2009, 04:25 PM   #2 (permalink)
fordman460
Posts: n/a
Re: 351C distributor
351C and 429-460 have the same distributor. Some 351w and 302 will interchange with a gear swap.
11-05-2009, 08:02 PM   #3 (permalink)
DanH
351W will , no 302 will
11-05-2009, 08:04 PM   #4 (permalink)
DanH
need the gear to match the type of cam -- steel roller or cast , what you got?
11-05-2009, 09:13 PM   #5 (permalink)
BrianS
Only the 302Cs from down under.
[SIGPIC][/SIGPIC]Yahoo 351C Forum Owner
BrianS is offline   Reply With Quote
11-05-2009, 10:29 PM   #6 (permalink)
fordman460
Posts: n/a
OOPS! Sorry for the wrong info! Thanks DanH, for correcting it. I am getting older you know!
11-06-2009, 09:39 AM   #7 (permalink)
DanH
your lucky,I'm already old
What Distributor for the next 351c ? gchero351 All Ford Techboard 16 07-12-2007 05:40 PM
Accel distributor on 351c help cyberhawk9 All Ford Techboard 2 10-01-2006 06:34 PM
Without distributor 351C Fredde71 All Ford Techboard 6 08-19-2006 06:06 PM
Without distributor 351C Fredde71 All Ford Techboard 1 08-12-2006 01:43 AM
351C MSD distributor airframe2001 All Ford Techboard 1 06-03-2004 05:49 PM
