11-05-2009, 09:11 PM   #1 (permalink)
77f100
what size stall do i need for my c6?
i'm going to buy this cam and all the info i know about it is. doesn't say what size just high stall. and the big question is what size is high? it's a 460 going into a 77 f100 reg. cab long bed. almost all street just a fun toy so to say.
Lift: .563/.588
Duration: 300/310
Duration @ .050": 234/244
Lobe Separation: 112 LC
Lopey idle, Good mid-range power
Rough idle quality - (Note: Intake vacuum may be too low for power brakes, etc.) Good mid-range torque in 3000 - 4000 RPM range. Good mid-range power operating range 2200 - 5400 RPM. Average fuel economy cam not recommended for towing. Increased compression ratio best, 10.5 to 1 or 11.0 to 1. Some engine modification required. Use manual or automatic transmission with high stall converter. Recommended spring pressure 120 lbs for valve on seat; 300 lbs for valve open. Axle ratio at 3.90 to 4.50 to 1 is best.
77f100 is offline   Reply With Quote
11-05-2009, 09:19 PM   #2 (permalink)
PaulS1950
Re: what size stall do i need for my c6?
For street use you have to decide what you cruising RPM is going to be - your torque starts in at about 3000 and peaks at around 4000 so For most applications as long as you are not hauling loads you can go with a 3000 rpm stall. You also need some steep gears - 3.7 to 4.0 would be best.
You will also need a lot of extra cooling - get the biggest trans cooler you can buy.
Paul's Street and Strip
Performance AODs & C4s
paulstephens@q.com
6522 51 Ave. S.
Seattle, WA. 98118
206.725.0881
11-05-2009, 09:24 PM   #3 (permalink)
77f100
don't know what rpm it is but 55mph 90% or the time.... gottta do that to cuz the police r bad where i gotta drive though.... but i know alot of back roads where i can have fun. haha was going to put a 4.11 or a 4.22 not sure thinking more of the 4.11s though.
11-06-2009, 10:48 AM   #4 (permalink)
mavman
I had a VERY similar camshaft (what brand and # is yours??) in my old '83 F100. It "liked" about 2600-2800 stall speed in the C6. Eventually that cam made it into a 514...with the same converter it was a handfull at full throttle and with 3.89 gears. I put a stock converter back in (came out of a School bus) that stalled 2000-2100 behind the same 514 (flash stall) but it was a LOT tamer, especially after I swapped in the 2.47 rear gear. Ran the 1/8 mile track in low gear and still ran some 7.90's and 8.0's on street tires. Never ran it with the other converter and 3.89's...though it was a LOT quicker.
Good luck
11-06-2009, 04:39 PM   #5 (permalink)
77f100
the cam is an elgin the part number is E-1057-P
2500 stall or 3000 stall? dsfordguy All Ford Techboard 23 06-13-2006 10:07 PM
Opinion question...tire size...big/little or same size? 673904spd Galaxie Pages 7 06-27-2005 08:01 AM
stall\'s??????? fender2k5 All Ford Techboard 1 05-30-2005 11:23 PM
too much stall crhumper C4 Transmissions 1 09-16-2003 10:42 AM
cam and stall strokerman All Ford Techboard 0 01-08-2003 06:00 PM
