Duraspark II question
Got the 5.0 roller motor in my truck. I hooked up the Duraspark II parts but found something that seemed very odd. The voltage drops when I connect the module to the power wire. I'm using the wire that provided 12v to the original 69 coil. When I connect the new coil the voaltage stays at 12v, add the module power wire it drops to 5.75 to 6v remove the wire it goes back up. I pulled the power from the switch side of the starter soleniod, same thing. Power direct from the battery stays at 12v. With the low voaltage the truck has a bad stumble at mid range, power from the battery clears it up. I don't mind running a new wire, adding a switch under the dash etc. So is this normal voaltage rates? Does this mean the module is bad or going bad? Sorry about the length of this post I just wanted to try and cover all the bases. Help...........Rick
