Go Back   FordMuscle.com Forums > Premier Forums > Tech Exchange > Body and Paint Articles
06-08-2008, 05:50 PM   #11 (permalink)
SCHOONER
Re: Unsightly Under Coating
Hi FatNFast
WOW ! What a GREAT presentation you made with just how 2 perpare and apply the Dupli - Color Bed Coating.
I'm sure going to follow you lead.
I notice the color of your car.
I have a '66 Mustang Convert. It looks like the color of my car.
Tell me if you will please what's the official color of you car ?
Thank You FatNFast
GOD BLESS YOU
Schooner
SCHOONER is offline   Reply With Quote
06-08-2008, 05:57 PM   #12 (permalink)
FATNFAST
That's my wife's 65 Hardtop. It is an original color called "Twilight Turquoise" Paint code 5 I believe.
Rick in Indy "408 Clevor" 9.64@137 1.30 60ft
06-10-2008, 01:54 AM   #13 (permalink)
SCHOONER
Question Hummmm ! Twilight Turquoise
Hey FatNFast
Mine is a '66 Convert. I don't know if I mention that before. I tend to forget even where the heck I live sometimes . . . .lol
Seriously, does the car paint have FLEX in it. You know like a sparkle in it ?
Thanks Guy
GOD BLESS
Schooner
06-10-2008, 03:22 AM   #14 (permalink)
FATNFAST
It's metallic.
06-26-2008, 06:56 AM   #15 (permalink)
ben98gs
Looks great... I would like to see it sometime. I do not get down there much anymore, but do you go to the Suds in Greenwood? Or the cruise in/strip in Noblesville (I have not been to that street/area, but a friend always goes/talks about it and takes pictures)?
ben98gs is offline   Reply With Quote
10-03-2008, 10:12 PM   #16 (permalink)
BlueOvalBandit
FYI anyone trying to take the easy way out by using chemical products like Eastwood undercoat remover. It doesn't work for this type of undercoat, I know cause I tried.
1337 |<3`/8()4l2l) <()/V\/V\4|\||)() 51|\|<3
41 6()|23 1|\|\/3|\|73|) 7]-[3 1|\|73|2|\|37
BlueOvalBandit is offline   Reply With Quote
11-06-2008, 09:52 AM   #17 (permalink)
wfritchen
when I cleaned up the firewall on my '64 Mercury, I used oven cleaner to soften up the sealer, then hit it with a plastic putty knife. Worked great! I don't think its the same as undercoating but worked so well it might be worth a try on the undercoating.
a couple things to remember:
1. use eye protection and a respirator. Also wear rubber gloves! This stuff is nasty.
2. I tried several kinds and found the EasyOff original works best. No cheapo store brands, no scented kinds
Walt
Hiawatha Iowa
64 Mercury Monterey Marauder
wfritchen is offline   Reply With Quote
03-02-2009, 09:29 AM   #18 (permalink)
Gydyup
Great stuff, I just finished doing the belly of my beast and fenderwells etc, at least up to the Trans.
I found the undercoat scrapped off easier without heat as well. One tool I found a huge help, and not as noisy and dangerous was an 80 grit abbrasive wheel (one of those composite things), put that on a die grinder and have at it. It made quick work of the old sealer and paint, took it to bare metal in no time without a lot of scratching you get with a cup brush. Also safer, no wires flying around. I throttled my die grinder back to keep the RPM down.
I didnt go with the bed liner, I found Rustoleum black Satin is awesome, worked well over the POR 15. Not a flat paint, but not a sheen, and less texture. Put on the cheesy hand gun attachment and lay on your back and shoot it.
Thanks, Gydyup
Gydyup - 67 Mustang Coupe
"old School"
03-03-2009, 07:02 PM   #19 (permalink)
66svt
Excellent tech help man I just finish my front inner wheel fenders. They came out great and now I'm doing the rear.
66svt is offline   Reply With Quote
04-06-2009, 11:23 PM   #20 (permalink)
BlueOvalBandit
Ok update... I gave it another go around after burning through some 60 grit roloc discs.... and it works pretty good. It seems once you break the top layer it can penetrate. After that I found a wire brush cup on an angle die grinder blows it right off (surprisingly the $2 HF packs hold up real well got about an hour on the cup and it still looks pretty new). It's able to easily get into all the nooks and crannys you cant get into with a putty knife.
Note: there was no way in hell it was coming off without grinding previously, it ate wire brushes like there was no tomorrow.
It is incredibly messy though. I recommend wearing a full tyvec suit, full face shield, and p100 respirator, and the standard gloves and safety glasses. If it gets on your skin it's nontoxic but says it can cause irritation although it had no effect on me and I had it everywhere face, arms, neck, inside my ears with no reaction.
HTML code is On
COATING HEADERS YoSteve78 The Garage 9 11-08-2005 07:27 AM
Jet Hot Coating? growlin351w All Ford Techboard 0 05-26-2004 05:19 PM
Top Coating POR-15 69convert All Ford Techboard 3 04-10-2004 12:13 PM
ceramic coating in L.A? dietzero All Ford Techboard 3 04-09-2004 11:29 AM
header coating\'s Gent All Ford Techboard 4 11-02-2003 09:05 PM
Probe Industries
