Go Back   FordMuscle.com Forums > Premier Forums > Tech Exchange > Body and Paint Articles
02-22-2009, 09:51 PM   #1 (permalink)
Gydyup
Floor Pan Seam Puller/heat Sink
It seems there are a few of us working on floor pans or other welding challenges I have had replacing the long fronts in my 67 Mustang is getting the seams to together, as well as occasional blow through when encountering thin metal or wider gaps than planned.
Copper/magnetic heat sinks in a restoration catalog that will prevent molten metal from dripping or blowing through the project which normally will prevent this, so I gave it a try. This gadget is not too expensive and it works ok, if both edges of your project are flush or flat. If not, there is too much gap between the work and the copper to be effective and it can make things worse.
I gave this some thought and expanded on the magnetic heat sink idea. I went to the local home supply store and picked up a short piece of 1”X 1/4” flat bar, a piece of ¾”X 6” copper pipe, some #6 X ¾ machine screws and nuts, and a couple of #10 fender washers.
Back in the shop, I first flattened the copper pipe in a vice to keep it uniform and flat, then I banged it a few times with a ball peen hammer to flatten the edges. I cut my flat bar to a six inch length, then scribed a line down the center, and marked to hole locations one inch from each end. I punched the holes then drilled a hole in each end. I then ran a #6 screw into each hole, and tacked if from the head to the flat bar with the MIG.
I then transferred the locations of the screws over to the centerline of the flattened copper, and drilled a corresponding hole into each end of the copper. Once all drilled and welded, I slipped the copper over the two studs. The ¾ copper flattens nicely to a bit more than 1”, giving the flat bar a nice edge.
Once the copper sink and backer are fab'ed together, I went to the seam in the floor pan (transmission tunnel) line and laid the sink up next to the area I wanted to pull together, and marked the bolt holes with a sharpie. I then drilled a 9/64 hole just below the seam in the good floor pan material. From under the car, I pushed the two studs through the holes, and then from inside the car I placed a fender washer and nut on each stud, and ran them down snug until the seam was pulled flat and the copper was snug up against the metal.
Then it was just a matter of tacking and welding the seam closed. When done, unscrew the nuts; drop it out, weld up the holes and your done.
Gydyup - 67 Mustang Coupe
"old School"
02-23-2009, 05:51 PM   #2 (permalink)
rmousir
Re: Floor Pan Seam Puller/heat Sink
That is a AWESOME TIP!!!!! Wish I knew that before I did my floor pans. That would have made my job turn out so much better. Live and learn. If anyone is doing this task on there cars, this will help make your job come out so much better than a lap job.
Sweet Tip. I will use that for the quarters!!
Thanks very much.
Richard
1966 Mustang Coupe
\'95 roller 302, auto
warmed up just a little
check out my site: http://budgetrestomod.weebly.com/index.html
rmousir is offline   Reply With Quote
02-23-2009, 06:35 PM   #3 (permalink)
Redneckracer21
I used a similar method to this when i did the floors in my mustang. As long as you can keep the copper pressed tightly to the metal your welding, it works pretty decently. Also nice write-up.
When the clutch drops, the bull**** stops.
Redneckracer21 is offline   Reply With Quote
02-23-2009, 08:20 PM   #4 (permalink)
Gydyup
Yep, screwing it tight to the work with the studs and nuts works a lot better than yelling at the wife to "close your eyes, and dont worry about the burns".
"old School"
02-23-2009, 08:48 PM   #5 (permalink)
one37tudor
If you don't happen to have any copper handy you can use aluminum bar stock the same way. I also made a cheep pannel clamp by taking a 6"X1"X1/4" piece of aluminum, slotting the center of each end about 1/2" and pinning a thin copper plate through each slot. I attached a threaded rod to the top of the copper and slipped it through a section of 1"X1" square tubing with a wing nut on the top.
This way you just slide the copper strips up between the two parts you are trying to butt weld, slide the threaded rod on the the copper and through the square tubing and tighten the wing nuts. You have a backup for the weld and you dont have any holes to fill afterward.
Scott...
02-24-2009, 04:47 AM   #6 (permalink)
dennis111
Nice tip--I've usually acquired my copper from the scrap yard and never thought of getting it from the hardware store.
Dennis
11.21@124.0 al naturale
My Racing Videos
02-24-2009, 05:10 PM   #7 (permalink)
Gydyup
Hi Dennis, I have more Home Depot and Lowes within spitting Dist than scrap yards. I wanted an electrical break bar, but they are pricey new.
Thanks for the help with the posts. Greatly appreciated.
"old School"
HTML code is On
1967 Galaxie rocker-to-quarter panel seam moosespears Galaxie Pages 2 03-07-2007 07:24 PM
Floor Board Heat sheilds jetnoise All Ford Techboard 0 08-13-2006 08:43 AM
pitman arm puller garner67 All Ford Techboard 4 05-19-2006 12:34 PM
Seam welding / general body strengthening kewolfe All Ford Techboard 3 04-02-2005 02:49 PM
Factory seam sealer 65Kcoupe All Ford Techboard 8 12-15-2003 08:52 AM
Probe Industries
