Go Back   FordMuscle.com Forums > Premier Forums > Tech Exchange > Braking Articles
01-14-2009, 06:16 AM   #11 (permalink)
68fastwilliams
Re: Early Mustang 13" brake upgrade
Originally Posted by n2omike View Post
Hmmm.... Your very first post.
Are YOU the one selling these kits? (glowing report, matching t-shirt, etc) LOL!
LOL! I wish.
68fastwilliams is offline   Reply With Quote
01-14-2009, 09:27 AM   #12 (permalink)
72BlackOnBlack
I'm definitely digging the wheels.... Great writup and pictures!
72BlackOnBlack is offline   Reply With Quote
01-14-2009, 06:39 PM   #13 (permalink)
lafngas
Does anybody know if one of these kits would work on a '65 Comet spindle? Are the spindles the same on a '65 Comet and a '65 Mustang?
-Greg
lafngas is offline   Reply With Quote
01-15-2009, 07:04 AM   #14 (permalink)
68fastwilliams
-Greg
Greg,
The spindles are the same, so this kit will work.
http://i64.photobucket.com/albums/h179/68fastwilliams/PapFDay.jpg
America gave us the promise of freedom. Ford gave us the keys.
01-15-2009, 10:25 AM   #15 (permalink)
pbrown
-Greg
You can also switch to the big pin 70-73 Mustang spindle. If your going to the expense of 13" brakes then it wouldn't be much more to upgrade to stronger spindles at the same time.
Patrick Brown
62 Falcon - 331 stroker - C4
pbrown is offline   Reply With Quote
01-15-2009, 10:36 AM   #16 (permalink)
hepcat69
what is the smallest diameter wheel that will work with the 13" discs? do they make a kit small enough to fit 14" or 15" cragars in the front?
Happieness is defined as daylight under the front tires.
hepcat69 is offline   Reply With Quote
01-15-2009, 12:08 PM   #17 (permalink)
68fastwilliams
With the 13" brakes you must run at least a 17" wheel. I'm not sure if 14" wheels would work but they do offer a kit for 15" wheels Street or Track 11.25'' Front Disk Brake Kit.
01-17-2009, 10:55 AM   #18 (permalink)
stoker
good point
I hope i dont regret it as i kept my 65 Oem spindles with my Baer13" rotors, Bump Steer hiem joint,and aftermaket TCP crome moly control arms upgrades
have you seen any spindle failures?
stoker is offline   Reply With Quote
01-17-2009, 06:16 PM   #19 (permalink)
StreetorTrack
Originally Posted by stoker View Post
good point
I don't think you have anything to worry about on street tires. If you road race on slicks or bounce the front down at the strip then maybe thinking about upgrading to the bigger pin.
You can still use your Baer kit with 70-73 spindles. All you need to do is change the bearings and races in the hub to the 70-73 bearings. A12 & A13.
The ball joints are the same so your control arms are ok but the pin on the bump steer kit is different...
StreetorTrack is offline   Reply With Quote
01-18-2009, 08:26 PM   #20 (permalink)
stoker
thanks for info
I actually bought the bumpsteer kit from you (believe it was Baer)?
My alighnment Guru had to machine the part that bolts to spindle (turned on lathe)to get the geometry right
I run Total Control A-arms
It seems bitchen now and you can slam on the brakes at 100mph and almost let go of the wheel,where before it was darting like hell
HTML code is On
brake upgrade. booboo412 All Ford Techboard 3 05-28-2009 03:45 AM
Cool suspension upgrade for early Galaxie caper150 Galaxie Pages 2 07-25-2007 12:16 PM
67 Mustang Rear Brake upgrade Gydyup Mustang Pages (1965-1973) 2 07-08-2007 07:58 AM
What would it take to upgrade an early 302 to 5.0 fuel injection? adgdghr123 All Ford Techboard 8 10-29-2004 12:11 AM
