10-26-2006, 07:38 AM   #71 (permalink)
atzi
Monster C4 Thread Text - Edited (Way Long) Version2
Here are some pictures i took of our C4 that twisted the input shaft and cracked open the forward drum , then strippe dout the inside splines. This is the second time this happened this year. We are running a fox body Mustang with 100 shot nitrous 302, 300 stall with trans lock running 7.50's and 1.60 60 foot. I learned alot from this forum about hardened shafts and weilded up forward drums so I purchased them and included them with the old parts in these pictures.
Here is a closeup of the cracked drum and the new welded drum. They weld up the peanut shape holes to streathen the drum hub.
atzi is offline   Reply With Quote
10-26-2006, 08:43 AM   #72 (permalink)
atzi
Sorry for the messpelling[img]/forums/images/smiles/icon_bow.gif[/img] 3000 stall not 300.
More pictures ...
These 2 pictures are of the input shaft next to the new shaft. Notice the twist on the splines that go into the convertor. Actually the end that went into the cracked drum was fine and untwisted.
Both drums next to each other.
12-20-2006, 10:44 PM   #73 (permalink)
64 TBOLT
<font size=-1>[ This Message was edited by: 64 TBOLT on 1/16/07 10:02pm ]</font>
09-22-2007, 12:26 PM   #74 (permalink)
slepe67
Re: Monster C4 Thread Text - Edited (Way Long) Version2
Hey, I copied this and saved it on my laptop. I'm out of town on business for a few months, and internet time here is very limited (only 15 minutes a day). I read the main article in entirety, but ,forgive me if this has already been asked/answered. I am totally ignorant on transmissions, and hope to rectify this situation. I just bought a "built" C5 from a friend (who claims it is good up to 500 HP-I plan on going up to 550 HP with a 347, in a 67 Mustang Coupe, mainly for drag racing), and plan on making it better.
First off, What is an R and H servo? Also, I see Trans Brake Valve bodies, and Reverse Manual Valve Bodies. Most of the orignal writers of the main article say they prefer Manual Vlave Bodies. What is the difference between a Reverse Manual, and a Manual Valve Body? Well, that is it for now, I'll be sure to write down my questions tonight for better reference. Thanks in advance. JL
1967 Mustang T/A Coupe clone/resto
slepe67 is offline   Reply With Quote
09-14-2009, 09:28 AM   #75 (permalink)
roger
Great information R code, tons of stuff i know nothing about!
I do have a nasty flare up on my ,well, 2nd over to 3rd shift(70 C-4 with a Gear vendor over/under drive attached)
If you know the GV units basicaly they split each gear for 6 forward speeds,
the neat thing is you only loose maybe 100-160rpm between gear changes so the engine is always in its sweet rpm spot.
but, as i said, on the 2nd hi if you know what i mean, to 3rd i get a nasty flare up. I;m running a Sonax billet servo,
Do you think the Sonax is not releasing quick enough? should i maybe try an R servo?
Thanks for any help, should mention, it doesn;t always happen, which is kinda scary too!
roger is offline   Reply With Quote
