05-04-2003, 12:31 PM   #1 (permalink)
nitemare
Reverse problem
C-4 problem. Go through the gears, have park, no reverse, nuetral is iffy, have 1st, 2nd, and 3rd. The Trans is a Performance Automotive competition with Trans brake.
In first the transbrake does not activate. Removed the valve body, transbrake solenoid operates. Fluid is clean, no metal or burning smell. Could it be reverse seal or stuck check ball in valve body? Don't want to remove trans if I don't half to.
nitemare is offline   Reply With Quote
05-12-2003, 01:14 PM   #2 (permalink)
nitemare
Reverse problem
Found the problem on my OWN, The foward clutch pack had welded together. Thats why neutral still tried to move the tires.
05-29-2003, 11:58 AM   #3 (permalink)
daffylong
Reverse problem
I have a similar problem with my C4.It works fine in all forward gears, no reverse.Did you have to take the tranny out to find and fix that clutchpack?I, like you, don't want to remove the tranny if I don't have to.[img]/phpBB/images/smiles/icon_confused.gif[/img][img]/phpBB/images/smiles/icon_confused.gif[/img]
daffylong is offline   Reply With Quote
05-30-2003, 06:34 AM   #4 (permalink)
gregaust
Reverse problem
No reverse you either have a rear band or servo problem.A servo can be repaired in the car ,but if the band is crook the trans has to come out..Remove the v.b and air test and see what you got.It is not uncommon for the rear servo pistons to go hard with age.
Probe Industries
