08-12-2003, 10:49 PM   #1 (permalink)
forthman
C4 Govenor
Is there a way to adjust the govenor so the shift point can be increased say to 4500 rpm?
01-11-2004, 09:45 AM   #2 (permalink)
64 TBOLT
C4 Govenor
i'm looking for info on that too
01-11-2004, 08:20 PM   #3 (permalink)
64 TBOLT
C4 Govenor
stu
(Login stuarta)
24.66.94.141 governor January 11 2004, 2:08 PM
A governor works under centrifugal force.
The more centrifugal force, the later a shift will occur.
There are two weights if a C4 governor. Don't worry about the small one.
The more mass will take less centrifugal force to throw the weights outward.
The mass can be reduced by drilling the large weight to reduce the overall weight. Drill either or both ends.
There is no magic formula for the amount of metal to remove but the more removed the higher the shift points will be. Just don't get carried away. Even a 3/8" hole 1/4 " deep will alter the shift points dramatically.[img]/phpBB/images/smiles/icon_tup.gif[/img][img]/phpBB/images/smiles/icon_tup.gif[/img]
01-12-2004, 06:46 PM   #4 (permalink)
64 TBOLT
C4 Govenor
is this the part hes talking about to drill??
