09-23-2003, 10:25 PM   #1 (permalink)
restomod
reverse high?
what the heck is a disc spring? and does anyone have pics of one?do i have too have one for my reverse high to work properly/ is this why i keep burning up the the reverse high clutch pack?somebody help!!!!!!![img]/phpBB/images/smiles/icon_cry.gif[/img]
restomod is offline   Reply With Quote
09-24-2003, 12:59 AM   #2 (permalink)
gregaust
reverse high?
The disc spring is the flat plate spring in the bottom of the forward clutch drum..The high/reverse uses a normal type spring.
09-24-2003, 07:31 AM   #3 (permalink)
Just Strokin
reverse high?
The disc spring is actually called a bellville spring when you go to buy one.
09-24-2003, 11:51 AM   #4 (permalink)
restomod
reverse high?
do i have too have one? does anyone have a reverse high that they can tear apart and take some clear pics of the clutch pac with the disc spring? gregaust and just strokin i am really confused now. [img]/phpBB/images/smiles/icon_confused.gif[/img]
09-24-2003, 01:06 PM   #5 (permalink)
Mario428
reverse high?
Starting to sound like a C-5 with the wave spring in the direct clutch pack.
Looks a lot like a steel plate but with a wave to it?
I would get some pressure paltes and snap rings and get a stack of plates and frictions that make the right clearance.
The wave spring will cushion the 2-3 shift and that is not a good thing.
09-24-2003, 02:01 PM   #6 (permalink)
restomod
reverse high?
the book i have is for a c5. the trannys are a 67 and 70 model c4s .what i need to know is, did either of my c4s have these springs . because if they did, i don't remember either one having these when i tore into them.
this is how i installed the clutches. i started with a steel then a friction, steel, friction, steel, friction, steel, friction. then last two were the pressure plate and the retaining ring. the clearance was at .035 . let me know if this is right.
09-24-2003, 09:44 PM   #7 (permalink)
64 TBOLT
reverse high?
http://www.mustangcentral.net/tech/c4/c4exp.gif
<font size=-1>[ This Message was edited by: 64 TBOLT on 9/25/03 9:46am ]</font>
09-25-2003, 07:46 AM   #8 (permalink)
gregaust
reverse high?
Yours sounds ok.The disc spring i meant was #37 in the diagram.
Mario might be onto something too.A c5 has the wave plate..Just leave it out if that's what you mean and go with the steels/clutches like you've done.
09-25-2003, 02:39 PM   #9 (permalink)
restomod
reverse high?
thanks guys[img]/phpBB/images/smiles/icon_tup.gif[/img]
