09-25-2003, 09:30 AM   #1 (permalink)
1967galaxie
Slip yoke Questions
What year of Stangs or fords came with a 28 spline slip yoke and also used a 1330 U-Joint?
1967galaxie is offline   Reply With Quote
09-25-2003, 01:08 PM   #2 (permalink)
Just Strokin
Slip yoke Questions
If you have a 1310 yoke for a C4 and a driveshaft with a 1330 yoke, you can by what they call a hybrid u-joint to mate the two together.
I don't remember, but isn't the 4spd yoke the same? Or is it the same as the C6 yoke?
09-25-2003, 04:27 PM   #3 (permalink)
1967galaxie
Slip yoke Questions
The C4,AOD, & T5 trans all have have 28 splines with a 1 1/2 seal dia. Some of these yoke took a 1310 u-joint and some a 1330, my driveshaft uses a 1330 u-joint and my yoke is the same it's just that my slip yoke has had it ad needs to be replaced, so to keep things simple I'd to use a 1330 u-joint in the front which is the same as the rear.
09-26-2003, 12:28 AM   #4 (permalink)
fogged408w
Slip yoke Questions
http://www.fordmuscle.com/phpBB/view...625&forum=17&1
Lakewood
