10-12-2003, 07:44 PM   #1 (permalink)
64 TBOLT
C4/C5 modulator valve
would it hurt anything leaving the pin out and vacuun line off the modualator valve and shift the trans manually.I installed a B&M Trans Pak in the comp mode[img]/phpBB/images/smiles/icon_confused.gif[/img]
10-13-2003, 01:12 AM   #2 (permalink)
gregaust
You will need to leave the pin in to hold the actual valve in place but will work ok with the line off as long as you are aware the 2-3 shift point will be fairly high even when shifting manually
Lakewood
