12-06-2003, 04:31 AM   #1 (permalink)
gchero351
vacuum modulator
After installing a full manual valve body on a c-4, what do you do with the vacuum modulator ? I will assume that you leave it in to plug the hole, but do you leave the holes where the lines go or went plugged or un-plugged ? are ther any adjustments to the modulator neccesary or is it now useless ? thanks , Greg.
gchero351 is offline   Reply With Quote
12-07-2003, 12:09 AM   #2 (permalink)
gregaust
vacuum modulator
Just put a plug over the end of the modulator to keep any water out .
