Sanity Check...re-building a C4
OK...thanks...I'll try it...as I was cleaning by VB, i carefully removed each valve and found one without a spring. Is this OK? In the Haynes Techbook, they show a typical vb and it shows a spring for each valve...but then again, my vb vvalves look nothing like in the book. Mine is completely different.
Do you guys know where I could get pictures of the various VBs? Mine is a 65. I drove a trany for about 4 miles before the teardown started, The only problem I felt was a slow shifting between the gears.
thanks
g
